System hangs when activating inserts
I've been having a problem for a while now, and haven't been able to track it down. When I open a large 5.1 session I have about a 60% chance of the whole computer hanging (mouse freezes, no force quit, no nothing but a hard reset). Protools will open, but when the session starts to load, when it gets to activating inserts, the system will hang. I have updated all the plug ins, I've set all the system prefs according to the "do this stuff first" post. I have done a clean install of the OS, Protools, and plugs. This all started when I upgraded to 7.4.2cs4 from 7.2, and bought a 4th HD card. I've tried removing the new card and opening a session, same problem. Re seated all the cards, same problem. Any insight would be appreciated.
Mac dual 2 gig, 10.5.8, PT 7.4.2cs4, HD4, Magma PE7R4, Sync I/O, 192, Mojo, Firewire PCI card for drives, built in firewire for Mojo, Waves 6, Altiverb, HD Pack, TL Space, RND plugs, Massey Plugs, Surcode PL II encoder.
Charles Dayton, CAS Twisted Avocado Post Audio http://www.imdb.com/name/nm0206743/ |
Re: System hangs when activating inserts
bump
Last bump
Try opening the session whilst holding down the shift key! this will disable all plugins in the session. now start to enable the plugins (command+control+click) one at a time and see how the session performs. this will tell you if its a plugin causing the issue which is 99% of the time the cause. Can you run other sessions ok? is it just this one session? you could start a new session and use import session data to create a new session incase of session corruption. could also try without any external drives connected!! Chris
Thanks for the response! I'll try your suggestion. Unfortunately, it's not just one session that does this. It's any large 5.1 session. It's also not consistent. I have about a 40 to 50% chance of opening any of these sessions. Many times, I'll be able to open a session, then I'll close it, and try to open another, only to have it crash while activating inserts. I do suspect it's a plug in, but all my plugs are up to date according to Digi's compatibility page. I have my suspicions about Altiverb being the culprit. I have the most recent version though.
Thanks again.
Hi Charles,
did you resolve this matter? I'm experiencing the same problem after upgrading and installing on a brand new system (pt9hd)
Asrock Fatal1ty X299 - i9 7960X- 128GB DDR4 - 3x m2 samsung evo 2TB pciex4 SSD - Geforce 3070 ti - Win11 x64 - PT HDX - HD Omni - HD I/O |
Ya... Did you?
Pro Tools 9.0.2 freezing on activating inserts | CatalystMusic | macOS | 0 | 05-23-2011 11:42 AM |
Session stops opening while Activating Inserts | A.J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 12:44 PM |
Frequent Hangs while activating inserts | Mark Wheaton | Pro Tools TDM Systems (Mac) | 2 | 08-15-2007 08:29 PM |
Activating hardware inserts,help! | speedyk5 | Pro Tools TDM Systems (Mac) | 1 | 05-20-2002 08:13 AM |
Freezes on Activating Inserts | essay | Pro Tools TDM Systems (Mac) | 2 | 06-13-2001 05:23 AM |
