Old 02-27-2019, 12:56 AM
gub gub is offline
Default K12 not working in PT
I have just acquired Komplete 12 upgrade (hardrive) and the Komplete Kontrol plugin within PT doesn't show up and when I open the FM8 or Absyn plugin within an instrument track no sounds appear.
Any advice please.
Old 02-27-2019, 05:07 AM
Default Re: K12 not working in PT
Any advice please.
System info?
You did install the stuff on the drive to your system right?
I don't think KK is supposed to work the way you're thinking; you first open KK and THEN select what you want. If you already have Absynth open why not just select your sound from within the instrument itself? Like FM8 it already has a way to select patches according to certain criteria.
Personally I never use KK.
Jack
QAPLA!
Old 02-27-2019, 10:51 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I was under the impression that Komplete Kontrol was for NI hardware mapping, esp for live use of NI synths with supported controllers.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-27-2019, 01:35 PM
Not necessarily. KK is their way of searching for sounds and doesn't need h/w controllers. A database control/search engine.
Jack
QAPLA!
Old 02-27-2019, 05:11 PM
Sardi Sardi is offline
And as of this morning, it now works with 3rd party controllers.
Old 02-27-2019, 10:22 PM
gub gub is offline
Yes I have followed proper install procedure. KK and PT worked fine together before and KK popped up as an instrument plugin.....but since jumping the K12.....nada....
Although, I did play around with FM8, absyn etc and they all work fine as an instrument plugin.... jut no KK
KK doest not appear in PT now
Old 02-28-2019, 11:55 AM
Do this: completely uninstall Komplete Kontrol. Then using NI Native Access reinstall KK. When done with that run Komplete Kontrol in standalone and let it do it's scanning which will take a while. When that's done just to see that things are working try selecting an instrument in KK. When that works quit KK. Open PT, create an instrument track, and for an insert go to the Native Instruments entry and Komplete Kontrol should be there.
Jack
QAPLA!
Old 02-28-2019, 11:57 PM
gub gub is offline
Thanks Jack, that worked .
Old 03-01-2019, 04:51 AM
Good to hear.
It's pretty much standard procedure with NI vi's to open each one in standalone before using it in your daw. Not mentioned anywheres on NI's site but more so in the music community.
Jack
QAPLA!
Digitest says my HD cards are working fine. So why aren't they working? tpcalm Pro Tools TDM Systems (Mac) 8 07-09-2020 01:34 AM
Import not working + Drag & Drop Stopped working royalg333 Pro Tools 11 1 06-08-2016 01:02 PM
DeckLink Studio 4K pci video out not working on PT10.3.8, but working on PT 11.3.2 abes Post - Surround - Video 3 04-18-2016 01:19 PM
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... Jon Vandenbor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2015 02:10 PM
Digi 002 - optical input not working / only DI channel 1 working Maulden7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2013 01:46 AM
