Closed Thread
Old 03-07-2018, 05:50 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Reason Upgrade to 10 for $99
For any of you still using Reason Adapted or Reason Essentials, you can upgrade to the full Reason 10 for just $99. Pretty sweet deal.
Upgrading from prior versions of the full Reason is still $129, though.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 03-07-2018, 09:13 AM
Sardi Sardi is offline
Default Re: Reason Upgrade to 10 for $99
Why on Earth would they not offer the same
Discount to R9 (the full version) users too?
Crazy!
Old 03-07-2018, 11:13 AM
DonaldM's Avatar
Crazy!
I wondered the very same thing! I guess they want to get more of the Essential/Adapted crowd on to the full version.
Old 03-08-2018, 12:59 AM
Becharax's Avatar
Becharax Becharax is offline
I am still on Reason 9.5 and happy about it
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 03-08-2018, 05:50 AM
DonaldM's Avatar
Me too. I don’t plan to upgrade anytime soon unless they add some significant new functionalities, not just more VIs. Being able to host VSTs while in slave mode would be a good start. Adding more MIDI routing functions would be another.
Old 03-08-2018, 08:14 AM
DetroitT's Avatar
DetroitT DetroitT is offline
UR not missing much at all.
Old 03-08-2018, 08:29 AM
YYR123's Avatar
YYR123 YYR123 is offline
I’m on Reason 7, sounds like it might be worth it for me
Daniel
Old 03-08-2018, 08:46 AM
I'm still on R8 believe it or not.
Do you by any chance have VEPro on your system? I wonder if that could be used as a workaround to get R9 and higher to host vsts while working for the main part in PT? I have VEPro 6 but just R8 like I said.
Jack
QAPLA!
Old 03-08-2018, 10:07 AM
DonaldM's Avatar
No I don't have VEPro. But I doubt it would solve the issue as you can't host VSTs with Reason in slave mode anyways. So, even if you somehow hosted Reason i VEPro without it being in slave mode, you'd still have to route the MIDI from Pro Tools to Reason to play a part, and then route the audio back from Reason to Pro Tools to lay down the track. I can do that now using virtual midi and the loop back audio feature on my Focusrite interface. So, I don't see how adding VEPro makes that any different. I just open Reason then Pro Tools to do things this way if I want to use patches created using VSTs in Reason. Mainly its in the Combinator in Reason that I do that. If I'm just going to use a single instance of a particular VST VI, then I can just host it directly in PT using Reaper or Patchwork.
Now, if Blue Cat made a Reason version of Patchwork...then that would make it so you can host VSTs in Reason while in Slave mode. Just host them in PW inside Reason. But, the REAL solution is for the P-heads to simply upgrade Reason to allow VST hosting while Reason is in slave mode. Frankly I don't see why that's an issue now. Reaper can host VSTs when in slave mode...it can't be that hard to pull off programming wise.
The other thing I want to see if MIDI cable routing similar to how we can route cables now on the back of the rack. Imagine if you had 2 MIDI out ports on, say, the Dual Arp Player, and could route Arp 1 to one VI and Arp 2 to a different one. Combinator set ups using that could become quite complex and textured. You could have a MIDI splitter, similar to the audio or cv splitters if you wanted to send a MIDI out to several VI's MIDI INs at one time.
Right now, MIDI functionality is very limited in Reason.
All of the above has been passed on to the P-heads by me a few months after 9.5 was released. I know they saw it, because I received replies asking me for more information as to what I had in mind. So, I'm hoping that means its under serious consideration, perhaps even being implemented. We'll see what happens if/when 10.5 or 11 is released.
But simply offering more VIs or FX is NOT going to justify an upgrade in my mind. I've had several Reason users tell me they agree with me on that, too.
Old 03-08-2018, 10:09 AM
DonaldM's Avatar
Daniel -- but remember from 7 it will be $129, not $99...unless you can get some kind of deal through some 3rd party seller.
Closed Thread
Any reason to upgrade to 12.5.2? PatriotsBiker Pro Tools 12 4 07-17-2016 03:43 PM
help with 7.3 upgrade and reason crowdpusha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-14-2006 07:34 PM
Reason Upgrade? DazedAndConfused 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-01-2006 04:22 AM
Reason 3.0 upgrade bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-03-2004 06:50 AM
Upgrade PT Reason Adapted to FULL Reason ...Price? bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-09-2003 07:04 AM
