any workflow "workarounds" for lack of automation trim in vanilla?
I got to say, i think this is silliest omission ever, even cheap daws have trim. In Logic, I was used to just grabbing a little fader on the track header and dragging it up or down (well a numerical number actually) and it would move all automation on the track up or down.
Now.. if i select all the automation on the track, and manually try drag it, it doesn't work.. which i was hoping the workaround would be. Anyone know? For volume I could use a vca and lower it, as that does everything relatively automatically. But that will only work for volume. Thankfully volume is usually what one wants to trim, but still.. any suggestions are appreciated. or avid, just add trim in 12.9 please! I can't believe i considered upgrading to HD for 1900 i don't have lol, just for trim. There's nothing else in HD i need. Not one thing.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
Re: any workflow "workarounds" for lack of automation trim in vanilla?
The other easy way to do it is with a plugin. The final plugin in your chain with an output volume would do the job, or a dedicated plugin. Slate has a free trim plugin for instance.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
and it is one of the big things i miss about HD ..
the trim in HD wouldn't do ALL the auto would it? Only what the user wants? For example if i'm trimming volume, i wouldn't want to trim filter frequency sweeps.
if i remember correctly, there is a trim for each Automation Kind ..
+1. For gain of a track in a mix (preserving automation moves already written) I adjust final plug output level. I find the automation breakpoints thing to be a bit crazy ... but workable. I try my best to first create a static mix, then tweak with automation as needed. My 2 cents !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Actually, the clip gain in pro tools is thought out so well, it's one of the main reasons i switched to it to begin with, seriously. It's awesome.
Can VCA Master be used as automation Trim in "vanilla"? | NipL | Pro Tools 12 | 2 | 11-04-2015 09:34 PM |
Trim tool requires breakpoint on clip boundary for "automation follows edit" to work | simonchase | Pro Tools 11 | 5 | 07-29-2014 06:41 AM |
Have an "incompatible system" -- looking for workarounds | sirprotools | Windows | 13 | 03-23-2011 12:05 AM |
Feature Request: "Trim" as Automation Mode | Dabeed | Tips & Tricks | 17 | 01-18-2010 03:14 AM |
No automation Trim? Workarounds please | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 12-14-2001 10:21 AM |
