Old 09-08-2017, 12:37 AM
Sir Hannes Sir Hannes is offline
Default PlugInAlliance: delete factory presets - but they regenerate automatically
as there are too many factory presets with PA plugins (e.g. ACME!) I moved them within the presets folder into a new one called "factory". Now I open up the plugin, I see only my personal ones. But after restarting PT12, all factory plugins are rebuild again.
I send already a request to PA and they say, next month they are looking for this. So I want to ask you, if you know how to handle that?
Thanks!
Old 09-08-2017, 04:32 AM
Default Re: PlugInAlliance: delete factory presets - but they regenerate automatically
I live with it. A lot of times I'll start with a factory preset and go from there.
Jack
QAPLA!
Old 09-08-2017, 05:06 AM
That will blockade my creative work to read all of that 100 preset names to find the correct one that fits. Nope, I will build up for my needs.
And often: I really don't know, what they mean with there names, e.g. dyn_eqv2 (ok, hihat was the only I used from the factory). Check alpha compressor. I think, this is just not my vocabulary...
Old 09-11-2017, 06:32 AM
sw rec sw rec is online now
Name your presets with numerical prefixes (like 001, 002, etc) and they should appear at the top of the list.
Old 09-11-2017, 07:00 AM
He wants to dump the factory presets and there's no known way to do that at this point in time. With Plugin Alliance plugs they have a separate menu item in the drop down for user presets.
Jack
QAPLA!
Old 09-11-2017, 09:28 AM
I did already, but not starting with first numbers: I did it with last numbers, so my presets appears above my mouse. But for example with ACME opticom and others that makes no sense as the created list is way too long.
Old 09-11-2017, 10:26 AM
I am seriously not understanding your first sentence. I don't see how numbering things your way would make the presets appear above your mouse; maybe it's the way you're describing it?
Can you give us an illustration of what you are really after? This is truly a case of a picture is worth more than a thousand words.
Jack
QAPLA!
HTML code is On
How to delete empty audio clips and files automatically in PT? Rockman413 Pro Tools 12 4 03-22-2016 10:46 PM
to delete transfuser internal factory presets ... metascanner Virtual Instruments 11 11-09-2009 01:10 AM
Any way to delete saved Waves presets? crizdee Pro Tools TDM Systems (Mac) 3 06-27-2007 06:32 AM
Factory presets are gone In-G Pro Tools TDM Systems (Mac) 3 09-17-2003 07:16 PM
Factory presets are GONE! marcelloz Pro Tools TDM Systems (Mac) 5 05-02-2001 07:53 PM
