Automation mode buttons not working
Hello,
I recently bought the Pro Tools Dock and I found out the automation mode buttons not working. I can't switch between read, touch, latch etc. When I change mode with the mouse in pro tools, the buttons lights are changing, although the green light on the read-button is still green during all other modes. I tried to change the buttons functions in Eucontrol to other tasks, to see if the buttons work or not. And they do, but not for automation modes, which they are meant for. What do you think is wrong? I have latest version of Pro Tools HD, Eucontrol and Pro Tools Dock firmware. Mac os 10.12. Mac pro 6-core 3.33 Thank you, Calle |
Re: Automation mode buttons not working
Are you following these instructions ?
To select track automation mode using the Dock Mode switches and the Control app: 1 In the Control app, tap Mixer or Tracks. 2 Bank the Control app so that the desired track is shown. 3 On the Dock, press and hold the switch in the Left Control section for the desired track automation mode (Write, Touch, Latch, TouchLatch, Trim, Read, or Off). 4 While still holding the automation mode switch, tap to select the desired track on-screen. |
Thanks EddieJones!
Now I get it, I just didn't understand how the automation modes was intended to be used, I must admit I didn't read the whole manual yet.. so much gear so little time.. I thought you pressed a automation mode-button for the selected track and then it would change directly. But this seems better! Maybe someone with the same question will find this answer. Cheers, |
Cheers, Stefan |
different question:
on an S1 (Mac) I would assume I could set the automation mode with the mouse in ProTools.... then make sure the fader is showing on the S1 then do fader rides correct? |
Theres an auto button on every rack on the S1...no need for mouse
and i use left hand for fader rides so my question remains... i assume I can select automation modes with mouse, and use fader? i would think yes.... ? |
Yes of course
S3 bug: track exits trim mode after writing send automation in preview mode | yoerik roevens | Avid S1, S3, Dock and Control App | 4 | 06-27-2017 10:38 PM |
Upgraded to PT 12.5 now automation buttons not working | bassmagnetic | Avid S1, S3, Dock and Control App | 3 | 06-13-2016 08:15 AM |
automation mode buttons/C8 channels follow track-selection automatically | clusterer | ProControl, Control|24, Command|8 | 2 | 11-24-2009 03:16 PM |
Automation not working during bounce mode | dtmprod | Pro Tools TDM Systems (Mac) | 6 | 05-17-2006 10:06 PM |
Read Mode + Latch buttons - solid on session start | CCash | ProControl, Control|24, Command|8 | 0 | 06-28-2005 10:16 PM |
