Old 06-25-2019, 03:09 PM
hellatall's Avatar
hellatall hellatall is offline
Default Crashing on startup with 10.14.5
Not sure what I'm doing wrong here. . . Been using PT for over a decade on various machines, versions, and OS's.
Installed 2019.5 on a 2019 MBPro running 10.14.5 today, cloud authorized via iLok, and I can't even get to the initial Avid screen.
Only 3rd party plug-ins are FF's Pro Q3, Xfer's Serum, and Output's Arcade.
Trashed all prefs (not that I had even created any) via PT Prefs. Re-started.
Same... icon bounces for a couple seconds and then "Pro Tools quit unexpectedly". . .
What totally bone-headed thing am I missing?
Primary:
2019 Macbook Pro 15inch
2.6ghz Intel Core i7
OSX 10.14.5 Mojave
16GB RAM
Pro Tools 2019.5
Secondary:
2015 iMac i7 27"
1TB SSD. 32GB RAM.
OSX 10.11.6 El Cap
Pro Tools 2018.3
Rosetta 200 I/O via X-Symhony into TB2 Akitio Chassis
Session and Sample drives in TB2 Akitio Thunder2 Chassis
Server:
2008 Mac Pro 3,1 2x2.8 Quad-Core Intel Xeon
Target Disk - OSX 10.8.5 Mountain Lion
22GB 800Mhz DDR2 RAM
Old 06-25-2019, 03:48 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Crashing on startup with 10.14.5
Might need to try a re-install... otherwise on the MBP compatibility list....
http://avid.force.com/pkb/articles/e...ols&popup=true
Supported Processors (Pro Tools | Ultimate & Pro Tools Standard):
Mid 2018 Retina 15" MacBookPro15,1 6-Core i9 'Coffee Lake' 2.9 GHz
Mid 2018 Retina 15" MacBookPro15,1 6-Core i7 'Coffee Lake' 2.6 GHz
Mid 2018 Retina 15" MacBookPro15,1 6-Core i7 'Coffee Lake' 2.2 GHz
Supported Processors (Pro Tools Standard only):
Mid 2018 Retina 13" MacBookPro15,2 4-Core i5 'Coffee Lake' 2.7 GHz
Mid 2018 Retina 13" MacBookPro15,2 4-Core i5 'Coffee Lake' 2.3 GHz
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
Pro Tools 2019.6-23.#, Cubase 9.5, Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 06-25-2019, 04:02 PM
deanrichard deanrichard is offline
I don't use PT much any more, but in the past when I had problems like that in v10 it was usually plugin related. Removing some of the plugins would eventually make the problem go away, but I can't say I was very scientific about it. If you've added any new plugins recently that would be a good place to start.
Could PT 2019 have installed some new plugs, or updated some of the old ones?
Old 06-26-2019, 11:07 AM
hellatall's Avatar
Indeed, my year is not on the list, but the specs are. I will attempt a re-install today.
Primary:
OSX 10.14.5 Mojave
16GB RAM
Pro Tools 2019.5
Secondary:
2015 iMac i7 27"
1TB SSD. 32GB RAM.
OSX 10.11.6 El Cap
Pro Tools 2018.3
Server:
Old 06-26-2019, 11:08 AM
hellatall's Avatar
It's actually a brand new install of PT on a brand new computer. No pre-existing versions or plug-ins other than the three I mentioned in my post, all of which are compatible according to their parent companies. I may remove them anyway, just to see, but otherwise there shouldn't be any other complications...**I would think**
Primary:
OSX 10.14.5 Mojave
16GB RAM
Pro Tools 2019.5
Secondary:
2015 iMac i7 27"
1TB SSD. 32GB RAM.
OSX 10.11.6 El Cap
Pro Tools 2018.3
Server:
Old 06-26-2019, 01:18 PM
hellatall's Avatar
Re-installed, no dice. Tried out 2019.6, and still no dice... Avid support put me on a call-back list yesterday and never called back. Email to Avid support has not been answered... Bought the perpetual license. Quite peeved with Avid right now.
Primary:
OSX 10.14.5 Mojave
16GB RAM
Pro Tools 2019.5
Secondary:
2015 iMac i7 27"
1TB SSD. 32GB RAM.
OSX 10.11.6 El Cap
Pro Tools 2018.3
Server:
Old 06-26-2019, 02:17 PM
xrekcor's Avatar
Yup can totally understand.... if you can msg Jeffro on here he can get things going and very helpful. hopefully others may chime in with some ideas but I'm sure alls no lost.
Rob
Old 06-26-2019, 04:06 PM
I'm not sure if this applies to Mac, but on the PC there is an "Unused Plugins" folder so you don't have to uninstall, then reinstall to find a problem plugin.
Old 06-26-2019, 04:50 PM
DigiTechSupt's Avatar
Hi, we can't find an active Avid Account under the Email you registered in the duc. Can you give us the case number of your support ticket so we could check?
Thanks,
Tope
Avid Audio Tech Support
Support FAQ
Old 06-27-2019, 02:02 PM
hellatall's Avatar
Thanks,
Tope
Apologies, the case is under my work account. Case number: 03733389
Primary:
OSX 10.14.5 Mojave
16GB RAM
Pro Tools 2019.5
Secondary:
2015 iMac i7 27"
1TB SSD. 32GB RAM.
OSX 10.11.6 El Cap
Pro Tools 2018.3
Server:
PT First Crashing on Startup SIU Telehealth Pro Tools | First Discussion 3 12-19-2016 08:25 AM
pt 11 crashing on startup lucidlife macOS 6 01-03-2015 09:41 PM
PT 9.0.5 Crashing on startup!! eanderso22304 macOS 3 10-05-2011 11:31 PM
LE 8.0 crashing on startup jbeband 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2008 11:00 AM
PT LE Crashing on Startup beggehorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-18-2006 09:18 AM
