Old 08-08-2018, 05:00 PM
georgeearth georgeearth is offline
Location: Echo Park , Los Angeles, CA, USA, Earth , Milky Way
Default Inactivating Inst Trx/CPU usage
So, totally have not really thought about this till recently, when I was reminded that inactivating an audio track that has plug ins running on it DOES NOT deactivate the plug in and hence, still is using CPU juice.
But that got me thinking, is the same true on instrument/midi tracks that have say kontakt or some VST running, that when I make them inactive (which I always do right after recording them to an audio track) that THEY are still using CPU? Any help (or abuse) is appreciated.
Old 08-08-2018, 05:29 PM
jjnssn jjnssn is offline
Default Re: Inactivating Inst Trx/CPU usage
I believe it is Bypass that leaves them active and using CPU, making plugins inactive does disable the plugins thus they don’t use CPU. That’s been my experience.
Do you have an example where it is different?
Old 08-08-2018, 06:46 PM
All plugins on an inactive track are inactive and SHOULD use zero system resources. Bypassed plugins still use power and still cause the same latency as when enabled(inactive plugins cause zero latency).
Old 08-09-2018, 03:01 PM
I guess just to be clear, I understand that deactivating any plug in then frees up the cpu, my question specifically was: if just deactivating an instrument TRACK itself (or even an audio track that is running plug ins) if THAT counts as deactivating the plug-in(s) it self (as opposed to actually deactivating the plug-in THEN deactivating the whole track...
Old 08-09-2018, 04:44 PM
Any plugins on an inactive track are also inactive(so no need to deactivate plugins first, just deactivate the track).
Old 08-21-2018, 04:07 PM
Thanks Dave! (can i call you Dave?)
Old 08-23-2018, 09:19 AM
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
CPU usage error?! System usage 2%... pascalmowla Pro Tools 12 3 03-10-2016 12:00 PM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Improved performance after inactivating Spotlight JackV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 02-15-2006 01:12 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
