Apogee AD-8000 and PT5.0 mix +
Which installations for connection Apogee AD-8000 and PT5.0 mix + are necessary? The configuration Apogee8000, Hardware setup (PT has not in the list of this interface), and other.....
Best regards *-tone |
Re: Apogee AD-8000 and PT5.0 mix +
I believe you just select an 888/24 i/o and it works. there is no Apogee "set up"
Try that first. Jules |
Jules is right - chose 888/24 and get going. You can configure the AD8k to react to some parts of the hardware setup dialog, but not all. Check the info on dip switch settings. I've got mine set to be completely independent (hardware setup has no effect) to avoid learning two systems of setting the thing up.
-adam |
Apogee AD 8000 | rattleyoutrunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-12-2004 03:55 PM |
Apogee AD-8000 | Vegeto | Pro Tools TDM Systems (Mac) | 1 | 11-01-2003 11:30 PM |
apogee ad 8000 | Ed Shrager | Tips & Tricks | 1 | 01-16-2003 04:04 AM |
Apogee AD-8000 | binacadude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-13-2002 12:50 AM |
AD-8000 from apogee | mpmb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-16-2001 05:53 AM |
