Old 12-01-2009, 10:02 AM
GS-DK GS-DK is offline
Default Waves Vocal Rider - TDM or RTAS
Hi
I am going to buy the Waves Vocal Rider, but not sure if it will be worth the investment to get the TDM version - and suggestions. I have lots of CPU power, so RTAS will be no problem.
Thanks for your help!
Old 12-01-2009, 11:06 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Waves Vocal Rider - TDM or RTAS
Originally Posted by GS-DK View Post
Hi
they are both quite efficient and very low delay, so Native should suite 99% of users. unless you intend to use many of them! then TDM might be better.
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 12-02-2009, 11:57 PM
Mark Dann Mark Dann is offline
The TDm version is significantly less delay. I use almost all rtas these days (new Mac Pro here), but I only use this plugin as rtas.
Old 12-02-2009, 11:58 PM
Oops, I meant to say that I only use it as tdm.
Old 12-03-2009, 12:04 AM
stoox stoox is offline
I was working on a session with about 56 or so tracks with a eq and a compressor on most of them and a vocal rider on all of the vocal tracks(Which were about 4 and about 9 with some different harmonies)
It was a really queen influenced rock track and the band had each member doing something vocally. They traded off on leads a lot and they all harmonized when they were not on the lead.
and the drummer even did a harmony on a part. Amazing band.
Old 12-03-2009, 08:46 AM
roberts roberts is offline
Hi
You will want to to print down your automation from Vocal Rider (very fast and easy to do) to you main track automation. As Vocal rider does save time but you still need to tweak the automation it records because I would not call VR 100% accurate.
Old 12-03-2009, 09:39 AM
bad jitter bad jitter is offline
I wonder if it would be possible to copy VR fader automation and paste it to volume automation.
Old 12-03-2009, 04:52 PM
Touchwood Studios Touchwood Studios is offline
Yes you can.
Old 12-04-2009, 02:08 AM
thin ice thin ice is offline
Did anyone get VR to work on Tiger? This is the first thing I have found that might make me upgrade from my stable 7.3.1 system.
Mac Pro 2.66 Quad-Core Intel Xeon
6 GB 1066 MHz DDR3
HD3 Accel PT 9.0.6, OS 10.6.8
Old 12-04-2009, 06:40 AM
Studio Dweller Studio Dweller is offline
Originally Posted by Touchwood Studios View Post
Yes you can.
How do you go about doing that? I tried copying the VR automation to the main volume automation, but nothing got copied.
Larry Bentley
Cellar Dweller Productions
PT 10.3.10 HD3 Accel PCIe, 192 I/O, Control|24
Mac Pro Harpertown 8-core Dual 2.8GHz, 10GB RAM, OS 10.9.5
> Waves Vocal Rider - Live Howardk VENUE Live Sound Systems 2 05-30-2010 05:32 AM
Waves Vocal Rider = Cheating? gsilbers Pro Tools TDM Systems (Mac) 3 03-14-2010 12:22 AM
Waves Vocal Rider bug. usastra Pro Tools TDM Systems (Mac) 2 01-05-2010 04:00 PM
WaveRider or Vocal Rider from Waves? TiPo Pro Tools TDM Systems (Mac) 8 11-06-2009 12:41 AM
Waves vocal rider crizdee Pro Tools TDM Systems (Mac) 8 11-03-2009 10:42 AM
