Old 01-21-2011, 12:24 AM
evertonlouvize evertonlouvize is offline
Post Can I use heat in PT HD 9 with a 003?
I'm looking foward to have a PT 9. Can I have PT HD 9 instead of PT 9, once I have digi 003? If the answer is yes, would I be able to work with TDM plugins and heat???
Old 01-21-2011, 12:46 AM
HD2 HD2 is offline
Default Re: Can I use heat in PT HD 9 with a 003?
No, and no.
Old 01-21-2011, 12:59 AM
is there any other way to use heat with my 003???
Old 01-21-2011, 01:02 AM
HD2 HD2 is offline
No. Heat is a TDM plugin
Old 01-21-2011, 01:04 AM
too bad! but thanx anyways!!!!
Old 01-21-2011, 08:48 AM
promixr promixr is offline
Here is a very beautiful plug-in from Nomad Factory that gives you some of that 'analog warmth' you are looking for:
http://imsproav.com/main/NOMADFMagnetic.html
it's also not very expensive and works fine in Pro Tools 9 LE on a 003!
You can try this out for free here:
http://www.nomadfactory.com/downloads/index.html
Eddie Sullivan
Long Island Mac Tech
http://long-island-mac-tech.com
[email protected]
631 786 3924
Freelance Mac/Pro Tools tech for hire. Metro New York Area.
Old 01-21-2011, 09:53 AM
Originally Posted by promixr View Post
...and works fine in Pro Tools 9 LE on a 003!
Just to clarify (and avoid future confusion) There is no Protools 9 LE. there is only Protools 9 and Protools 9 HD.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 01-21-2011, 10:16 AM
lol- yes! my bad- and to clarify further- Magnetic will work on an HD system as well as an RTAS plug-in : )
http://www.nomadfactory.com/products...tic/index.html
Eddie Sullivan
[email protected]
631 786 3924
Old 01-21-2011, 10:40 AM
AndyJCP AndyJCP is offline
If you have a PT9 HD license and start it without the HD hardware, you get PT9 with the Complete Production Toolkit 2.
Which means PT9 + more tracks + VCAs + advanced automation + ...
But unfortunately, the ... does not include HEAT, which is a pure HD feature at the moment.
The same holds for TDM.
Old 01-21-2011, 10:57 AM
slater05 slater05 is offline
You can only use TDM plugins with Pro Tools HD TDM HARDWARE. The Same goes for HEAT.
You do have the option of getting the complete production toolkit 2, which essentially gives you all the HD9 features.
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
[IMG] code is Off
Does comping to a Heat enabled track print the Heat? joshdrucker macOS 0 03-12-2014 10:17 PM
Heat? or Something Like it? Numi Pro Tools 9 24 06-11-2011 06:13 PM
Something like Heat for LE? DonaldM Tips & Tricks 15 02-04-2011 02:20 PM
HEAT and PT 9 non-HD chicken Pro Tools 9 1 11-10-2010 06:43 AM
Heat vs VCC [email protected] Pro Tools TDM Systems (Mac) 24 11-01-2010 05:36 PM
