All the internal Avid plugins failed to load
I downloaded Protools 12.8.2 from my account, and installed it. However all the stock protools plugins fail to load. Not valid 64bit AAX plugins. Can anyone help with this?
Macbook Pro 2012, macOS 10.13 PT 12.8.2 - Apogee Duet 2 Apogee Ensemble, UAD 2, and plenty of plugins. |
Re: All the internal Avid plugins failed to load
anf then restart computer and restart PT .. PT will rebuild the Stock Plugins !! see if that works for you
OK i did what was listed, and that didn't work. I'm confused now because only the following don't work. There all dated 4/11/2016, while all the other plugins show today's date.Included picture blelow
i see you are usinf 10.13 .. unsupport at the moment .. is your drive formatted as MacOS extended or the new format APFS is it ??
I'm actually running this on Windows 10 :)
oh ok ... if you have not tossed your prefs .. !!!
here is the PC version of Pref App .. https://www.pro-tools-pc.us/category-s/1514.htm and here is the way to toss prefs on windows IF You NEed it without the above app .. https://www.sweetwater.com/sweetcare...s-preferences/
tried but still didn't work
Reinstall PT and try again. This is nothing I have seen so something is avry with the install and or something fishy on your system.
It sounds like something's not right from the install. Was this a fresh install or did you install over a previous version of Pro Tools?
Whatever the answer, I would do a clean uninstall and then re-download the 12.8.2 installer and make sure to watch that everything during the installation process goes smoothly. Sent from my iPad using Tapatalk
System Expected List Failed To Load, S6 time-out and S6 Network Ghost? | jp.donnelly | Avid S4/S6 | 1 | 10-25-2017 09:11 AM |
Constant re-authorizations and failed plugins | cpaul | macOS | 4 | 09-26-2017 09:09 AM |
PTHD 12: Quicking Wrapper Plug-in Failed to Load | catsynth | Pro Tools 12 | 0 | 04-23-2017 01:46 PM |
Pro Tools 10 not load plugins,freezing load.HELP | javierboz | Windows | 2 | 11-08-2012 04:25 AM |
ProTools 8 Fxpansion VSTs "The plug-in failed to load" | balveniediggz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-27-2008 09:30 AM |
