Changing volume of grouped tracks
Hi everyone,
it might be me misinterpreting the functionality of edit and mix groups but shouldn't it be the case that if I create, say, a drum group with 12 tracks and I move the volume fader of one of those tracks in an active group all the other faders should move relatively to that fader? I know it is possible with a VCA and I do use that but is that really the only option to simultaneously change the volume on more than one track? I'm pretty sure I saw people doing that only by grouping or selecting several tracks without using a VCA but maybe I'm just confused. Software used is Pro Tools 2018.12. Thanks in advance for bringing some light into the dark :) |
Re: Changing volume of grouped tracks
When you are creating the group you have to specify what parameter you want to be grouped, including volume, mute/solo, pan, etc..
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Yes, I've done that (I suppose): https://imgur.com/a/e0sN9C3
So I have "Follow globals" activated on each group and the settings are as shown on the screenshot linked above. Is this maybe where I'm doing something wrong? |
Well, my has brain has been melting over this issue for months now and now I just found out what the problem was: It works only as long as there are no Aux tracks in the group. Since I usually add at least a kick and a snare aux in a drum group, this didn't apply anymore.
I feel a bit dumb now but at least the problem is solved. :) |
Now it gets embarassing: That wasn't the problem either. The truth is: It works as long as there is no VCA assigned to the group. Sorry for the mess I created.
No worries. Welcome to the community!
Saw your follow up. Yes, a group used for a VCA can't then be used for group functions. What you can do (and I do) is double the same group. One group letter assigned to a VCA and the other (of the same tracks) just grouped.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Some how grouped all tracks | RareBreedMetal | Pro Tools M-Powered (Win) | 2 | 02-11-2011 08:39 AM |
arming grouped tracks? | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-20-2010 02:08 PM |
Grouped tracks changing playlists | tonicjeff | Pro Tools TDM Systems (Mac) | 0 | 09-17-2009 04:25 PM |
PTHD 8 grouped tracks | MEAT | Pro Tools TDM Systems (Win) | 8 | 12-24-2008 06:41 PM |
all tracks are grouped together | Cayotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-06-2005 11:51 AM |
