ATT DIGI: Will RTAS EVER Have Multiple Outpus?
When Kontakt and MachFive are released in RTAS format, there will no way to route different patches to different outputs under the current RTAS setup...this is completly insane. It means multiple passes to do drums, orchestras, etc. The idea that you can instantiate the amount of plugs that you would need to in order to do this is not feasible.
Will there be a solution to this? |
Re: ATT DIGI: Will RTAS EVER Have Multiple Outpus?
Hey Tom,
If your computer is fast enough you can have multiple instances of RTAS plugins on seperate tracks. For instance, with sampletank you could launch 2 and have keys on 1 and drums on another. Not the best way to work but it is possible. I assume that when rewire is implemented you'll be able to do the kind of routing you want with rewire compatiable programs (reason, live) |
Monitor Outpus 3-4 on Mbox 2 Pro | msdawe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-19-2011 05:55 AM |
multiple instances of RTAS | xartrax | Virtual Instruments | 6 | 03-15-2009 12:37 PM |
Multiple RTAS windows | Matt_82 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-14-2008 02:01 PM |
RTAS Engine Weaknesses with Multiple Processors Clicks, Buzzes,.. etc. | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-28-2008 04:26 PM |
Digi, RTAS Multiple Outputs When ? | Dutchmuzik | Pro Tools TDM Systems (Mac) | 3 | 10-26-2004 10:48 AM |
