Duplicating Regions not always lining up on Grid
I have a question and I know this has something to do with how many samples are in a "tic"/Beat...
however, When you copy and paste or duplicate a region that is exactly a bar in length on the grid, why does the transient or the region shift off of the grid? I've found this happens when I check a client's click track to the grid. The transients shift a sample or two back and forth. If anyone can explain the technical reason for this, I'd appreciate it. I'd like to understand how this happens a little more.
If you try to fail and succeed, what have you accomplished? |
Re: Duplicating Regions not always lining up on Gr
i can't explain why it happens, but it happened to me a lot. What I ended up doing was creating one measure of click, or whatever, checking to make sure it was perfect, and then consolodating it. For some reason, the act of consolodating it made sure that it never waivered from the grid, no matter how many times that it was duplicated. Works consistently for me,, anyway...
Re: Duplicating Regions not always lining up on Grid
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
hey bro, thanx for the link to that thread.
that's definitely shed some light on this issue for me.
Off grid when duplicating samples or regions | critza | macOS | 2 | 10-27-2012 11:03 AM |
Click track not lining up to grid.. any thoughts? | ratava911 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-18-2012 05:38 AM |
Not aligning to the grid when duplicating loops / regions. Off by small smaples. | xstortionist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 03-11-2011 06:47 AM |
duplicating audio regions on the grid | marcnyc | Pro Tools M-Powered (Mac) | 1 | 07-08-2010 04:11 PM |
duplicating midi/inst regions auto-joins regions? | WestphalMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-10-2009 09:44 PM |
