Old 06-20-2018, 08:12 AM
Rockman413 Rockman413 is offline
Default Rewire Pro Tools into DP or vice versa?
Just wondering can PT act like a rewire master or slave to work with DP?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 06-20-2018, 10:07 AM
Top Jimmy's Avatar
Default Re: Rewire Pro Tools into DP or vice versa?
Pro Tools can only do Rewire as the host, not the instrument.
James Cadwallader
Old 06-20-2018, 01:09 PM
DetroitT's Avatar
DetroitT DetroitT is offline
DP is also master-rewire.
However using midi timecode you can slave in either direction.
Plus other methods depending what your actual goal would be.
Old 06-20-2018, 07:39 PM
If both program are Rewire master, then I'll have to forgot about rewire...
The benefit of Rewire for me is to get rid of the sound flower's latency, and also to keep the TEMPO in sync between two DAW.
Old 06-24-2018, 09:36 AM
DetroitT's Avatar
https://reverb.com/news/how-to-combi...ws-with-rewire
Old 06-24-2018, 02:03 PM
Originally Posted by DetroitT View Post
But you still can't use DP rewired into PT and vice versa. DP does NOT show up in the instruments list in PT. Same thing for DP - PT does NOT show as an instrument in DP.
A long time ago you could use DP as a 'front-end' for PT. See this page: http://motu.com/techsupport/technote...-compatibility
Jack
QAPLA!
Old 06-24-2018, 04:51 PM
DetroitT's Avatar
Same with pre-Apple Logic
(DP and Logic could utilize the DAE engine).
I don't recall it ever being solid. Nor lasting more than a few years.
pick you battles. There are many alternative ways to utilize multiple DAW's
I prefer the separate I/O engines (Separate clocks) method.
Patchbay, IAC bus....
Syncing MV 8k w/ PT or vice versa MookHustle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-07-2005 09:52 AM
Man to woman or vice versa 2fly Pro Tools TDM Systems (Mac) 6 05-14-2004 06:51 PM
L.E. TO H.D. and Vice Versa HELLLLP Robby Hamilton Pro Tools TDM Systems (Mac) 1 03-10-2003 05:49 PM
L.E. TO H.D. and Vice Versa HELLLLP Robby Hamilton Pro Tools TDM Systems (Mac) 0 03-10-2003 03:01 PM
Syncing PT to 2" and vice versa... PeeTee Tips & Tricks 10 03-17-2001 01:49 PM
