#41
Re: Digi MIDI i/o Duplicated and greyed in Audio/Midi setup
OK! So I have upgraded to Lion with a clean install and have had problems with the Midi I/O duplicates as usual. I have determined that the duplicates occur for me when switching between apps such as PT, Logic, Live and Reason. Today, instead of rebooting, I decided to launch the AMS and just drag my connections over to the new duplicate "Midi I/O 2". I use all 10 ports for all my gear and I was feeling lazy ... so I tried connecting my midi devices to both Midi I/Os. The AMS allowed it and it works!!!!!!!!! So all my devices are connected to 2 duplicate Midi I/Os at the same time. The virtual cables are all over the place like a spiderweb. So far, I can switch back and forth as much as I want without loosing the connection to the Midi I/O!!!!
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
#42
So this is still working great. The AMS stays locked on Midi I/O 2 and the duplicates are gone. If you are still having issues..try it out.
#43
i have seen more that 2 IF's tho... maybe hook up to the 3rd one! ;-) ok try this! after a boot, launch AudioMidi Setup... see what InterFace'(s) are present and not grayed out! quit AMS launch AMS, are the same IF's present? quit AMS launch AMS, is it the same? or do you have a different configuration? when i have 2 IF's , one connected, one grayed out, and i go thru many lauch/quit cycles of AMS, the config actually changes back and forth...one time IF#1 will be connectd and IF#2 is grayed. then next launch the IF's are present but opposite online and grayed out.. i can repeat this over and over every time i launch AMS... bizzzarrr! thoughts???
thanks, brad Mac Pro: PT 11.3.2 HD native, MIDI IO, 96IO Mac Pro Desktop 4,1 osx 10.11.6., 8 Core 2.26GHz 2009 Intel Xeon MB535LL/A 16GB RAM 640GB HD ATI 4870 ----- MBP: OS 10.11.6, MacBookPro 5,1, Intel Core 2 Duo 2.4GHz Memory: 8 GB Bus Speed:1.07 GHz, Boot ROM Version: MBP51.007E.B06, SMC Version (system):1.33f8 |
#44
Here is a screen capture of my AMS. http://www.freeimagehosting.net/n5fv2
I only have 1 Midi I/O and it stays online all the time on "Midi I/O 2". I cannot tell you why this works, but it does!
#45
Could you resolve your problem ?
So, are these Digidesign Midi I/o working correctly on snow leopard/ 2009 & 2010 8 core Mac Pro's , with PT 9 HD (as well as with PT8 and PT7) ? |
#46
hey super!
i did what andy suggested and it seems to work... i launch audiomidi setup so it locks in the IF. then launch pt... it worked much better with os 10.4.9, now with 10.6.8 it does not... will be looking for a new IF at some point...doing things this way is really micky moused
#47
I had similar problem with a motu mtp av usb.
after many trials and troubles I have noticed that the motu driver had been installed in Mac HD> Library> Audio> Midi drivers I moved they to users> my occount> Library> Audio> Midi drivers and solved. It seems that in this case there are no very specific rules, my can be a solution that works but not the certainty! |
#48
Flying Rock Studios |
#49
#50
way to go ghost! b
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 10:13 PM |
Remove a Greyed-Out Device in Midi Setup? | Reesho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-14-2016 12:58 PM |
Midi IO not shown in AMS or is greyed out. When greyed out no MIDI options in Tools | drewsmith | Pro Tools TDM Systems (Mac) | 3 | 10-15-2011 06:21 PM |
Midi Regions / Losing the first midi note when duplicated | sad1robot | Pro Tools TDM Systems (Mac) | 8 | 02-10-2010 05:40 PM |
Can't see the Digi in the Audio/Midi setup | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-01-2003 08:27 PM |
