Old 06-14-2007, 08:25 PM
Lil G Lil G is offline
Default DAE error (-9129) need help!!!!!!
Hi all,
I am getting this DAE error (-9129) "audio Processing is conflicting with other CPU task, i browsed thru the answer base, and found out, i have to enable DMA on my recording disk, i am using a DELL Dimension 3100 P4 1GB Ram 3.0GHz processing with XP Home. PTLE 7.1 Mbox 2.
The problem is i cannot find where to enable the DMA on the Control Panel -> System -> Device manager.
I am at the moment using an internal drive, for my sessions, it works fine except for this error, if i have to change to an external drive, please let me know what type, pref USB conected.
Could you guys help me out here...Thank you
Old 06-14-2007, 10:15 PM
spkguitar's Avatar
Default Re: DAE error (-9129) need help!!!!!!
Instructions for how to do that, as well as other configuration and compatibility suggestions are in the General Troubleshooting thread at the top of this forum.
Then it doesn't work fine.
You definitely need to be using a separate physical disk for your audio sessions, but it doesn't have to be an external drive, it can be a second internal drive. If you decide to go for an external drive, keep in mind that USB drives are not supported or recommended. Firewire drives with the oxford 911 chipset are the recommended external drives. (that information is covered in the thread I linked you to above, and on the links within it).
Old 06-14-2007, 11:31 PM
thanks dude, i will get the firewire xternal drive.
Old 06-14-2007, 11:32 PM
9129 error whispermode Pro Tools TDM Systems (Win) 0 09-01-2009 03:31 AM
Need Help With 6.4 LE (Error (-9129) ryankasdorf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-14-2005 09:36 AM
Error -9129 K C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-02-2004 05:56 PM
6.4 Error -9129, huh? BIg Mick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-05-2004 10:30 AM
Please Help !!!!!!! 9129 error brucegoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-10-2002 04:20 PM
