Old 01-13-2024, 09:20 PM
tomaspal tomaspal is offline
Default PT Atmos Offline Bounce vs Rerender From DAMF
Has anyone seen discrepancies between offline bouncing rerenders from PT vs printing a DAMF and then exporting rerenders from the renderer? I usually create a master file and then export rerenders from the renderer for deliverables. For bouncing out WIPs, I’ll sometimes export directly from PT. I’ve never noticed an audible change between the two when listening down but have never directly A/B’d. Today I had a project where I noticed bouncing a stereo full mix rerender from PT resulted in a file that was about .7 LFKS louder than printing the DAMF and exporting the stereo rerender. Is this a known thing? Any insight on what’s happening under the hood differently between the two methods? I know there are some offline bounce issues with 2023.12, but I haven’t found anyone talking about any issues before that.
Running PT Ultimate 2022.7 and Dolby Atmos Renderer 5.2.0 on macOS 10.14.6. Renderer is running on a separate Mac Mini with audio running over Dante.
Old 01-17-2024, 09:08 PM
Tone_Mechanic Tone_Mechanic is offline
Default Re: PT Atmos Offline Bounce vs Rerender From DAMF
In the Renderer 5.2 release documents it mentions that there are changes to how Rerender are generated, having removed the spatial emulation algorithm. It specifically mentions that this may change the loudness measurement on 5.1 Rerenders. The latest version of Pro Tools (2023.12) should be updated to reflect these changes.
Old 01-18-2024, 08:49 AM
Ah that makes sense. Though I would have thought that bouncing from PT would still be using the external renderer (5.2 in the case) to encode rather than something built into PT. I'll test it out with 2023.12 to see if they are a 1:1 match.
Thanks for the response!
HTML code is On
Atmos Offline bounce Rendered on 2nd machine Goombot Pro Tools | MTRX & MTRX Studio 2 08-03-2023 01:03 PM
Pro Tools Quick Tips: Offline Bounce of Dolby Atmos® Re-renders Avid Avid Pro Mixing General Discussion 0 06-30-2022 01:13 PM
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Bounce Mix offline makes longer bounce than 'online' GregX Pro Tools 2 11-17-2021 12:42 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
