Old 12-15-2010, 06:01 AM
JazzyJ JazzyJ is offline
Default Recommendations for an Audio Interface?
Hi all,
now PT 9 is out there are loads of options for Audio Interfaces.
Can anyone recommend any good interfaces for use with a 13' Macbook Pro that have the following:
1) LOW latency
2) Minimum of 4 Audio Inputs (not including SPDIF)
3) USB 2.0
4) or if Firewire, that they can be Chained. (The Prism Orpheus can't be chained to firewire meaning that it can't be used on a 13' or 15' Macbook Pro and thus I have a dilemma)
5) Minimum 96khz 24bit recording
Any help would be appreciated
As stated the Prism Orpheus can't be chained to the Firewire and as the 13' Macbook only has one FW port is can't officially be used as both the Audio HD and Audio Interface will be on the same BUSS. Orpheus won't support it being chained and Avid won't support USB Audio Drives on Macs......
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 12-15-2010, 01:25 PM
The Dougfather The Dougfather is offline
Default Re: Recommendations for an Audio Interface?
Jazz,
I had my eye on the TC Konnekt 24D for years and finally picked one up on ebay for £100. It's a cool interface because it's not as big as a rack unit but does have ADAT and SPDIF so plenty of room for I/O expansion.
TC have been slammed in recent years for their drivers and think things now have settled down. I have been running the konnekt with Logic on 32 samples and in Peak at 192Khz and i haven't even experienced a dropout, unlike my 002R. It even has some onboard DSP, not for pro tools sadly.
Unfortunately, i think for TC the mud stuck but the price of their units second has plummeted, worth taking advantage of IMHO.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 12-17-2010, 01:58 AM
Cheers Doug, will check them out!
PT11 / OSX 10.8.5
Old 12-17-2010, 04:40 AM
lincol1 lincol1 is offline
I just added an RME fireface UC, an 18 I/O usb interface with latencies on par with with PCI. It has a solid clock, solid drivers, good AD/DA, sample rates up to 192k, buffer as low as 32 (64 in pt), 8x8 analog, 2 mic pres, ADAT, SPDIF. (2 ADAT @192, 4@96, [email protected]) WC I/O.
Also comes with Total Mix, which runs on DSP provided by the UC, which is a routing/monitoring app which after getting the hang of, is a very powerful tool with many advantages to simply monitoring in pt alone.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 01-09-2011, 04:37 AM
Sonic Nomad Sonic Nomad is offline
Originally Posted by The Dougfather View Post
Jazz,
This is true the drivers where really bad at one point. I believe the development was outsourced and TC then took it back and climbed in and sorted it out. Unfortunately the Konnekt range got bad cred in this time any many users got burnt and remain bitter. The latest drivers are great.
Need a new Midi interface for HD - Recommendations please... Actionmusic Pro Tools TDM Systems (Mac) 6 04-09-2008 03:19 PM
set-up recommendations and midi interface question maisbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-24-2005 04:01 PM
Interface recommendations for Panther? RKrizman MIDI 0 07-01-2004 11:49 AM
Off topic Midi interface recommendations? Rednroll Digidesign Hardware & Software 0 11-10-2000 04:23 PM
Help Midi interface recommendations Rednroll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-10-2000 04:13 PM
