Old 01-20-2019, 02:57 PM
SteveGarman SteveGarman is offline
Default Can I run PT 2018 Ultimate?
I have a MacPro Mid 2012 running PT 12.8.3, It's a 2x2.4 6-core with 32 gigs of ram and an ATI Radeon HD5770, 1024mb running OS 10.13.4.
I probably wouldn't need Ultimate, but I'm paying for it on subscription and might as well have it if it will run OK. I have an HD I/O interface and Sync HD, an SSD system drive and fast OWC drives for everything else. Can I run Ultimate? Appreciate your help!
Old 01-20-2019, 03:30 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Can I run PT 2018 Ultimate?
I don't see why not I am running it with my Mac Pro (below)
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 01-20-2019, 08:02 PM
Southsidemusic's Avatar
If you want to use the HD i/o Interface you need a HDX or HD Native pcie or the HD Native thunderbolt box as the old TDM cards doesn’t work above HD10.
You also need a digilink license for that so check that it is included in your Ultimate license. Otherwise it’s a $299 expense.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-21-2019, 10:27 AM
I neglected to mention I have an HDX card in my MacPro now plus outboard for the HD I/O 8x8x8 and Sync HD. Does that improve my chances for success with Pro Tools Ultimate? I am running 12.8.3 now and it seems very happy in OS 10.13.4
Steve
Old 01-21-2019, 12:22 PM
So your current software is 12.8.3 HD? Yes? "Ultimate" is simply "HD" in the new numbering scheme(and you MUST use the Ultimate version if you wish to come up to date. The non-Ultimate version of PT will not work with the HDX card or HD IO box.
Can you run Ultimate? Probably, but this is the important thing to answer:
Can the tower run the proper version of OSX that is compatible with the version of Ultimate you have access to?
Having said that, I would not make any change without a backup strategy. If the update goes sour, you want an easy way to get back to your current working setup. Then, might you get more bang for your buck by upgrading the CPU to the fastest 6-core, or going all the way and upping your computer to dual 6-cores
Old 01-22-2019, 06:33 AM
K Roche's Avatar
If I am not mistaken I think his Mac as is, can run up to PTHD 2018.12 on HS 10.13.6 beyond that, looks like to go to Mojave he would (like me) have to upgrade the graphics card
System :
Enjoy the Journey
.... Kev...
Old 01-22-2019, 08:41 AM
the.engineer the.engineer is offline
El Capitan and above all use the Metal framework that apple brought in to replace open gl and open cl. I would recommend an upgraded graphics card using any of the new OS’s.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 01-22-2019, 04:50 PM
K Roche's Avatar
Interesting I did not realize that. I am still running the stock (ATI Radeon HD 5570 1020MB) graphics card with HS 10.13.6 with no issues. I know Apple specifically recommends that Mid 2010 --Mid 2012 machines upgrade from the stock graphics for Mojave. but was not aware of it for El Cap -S and HS .
System :
Enjoy the Journey
.... Kev...
PT 2018 vs. PT Ultimate - What is the difference? danieleither Pro Tools 2018 2 01-16-2019 11:38 PM
2018.12 Ultimate - VCA Bug TrentWilliams Pro Tools 2018 2 12-15-2018 01:12 PM
Pro tools ultimate 2018 Jaymoney0079 Pro Tools 2018 3 11-28-2018 11:12 AM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
S6 M10 v3.5 works with PT ultimate 2018.4 ? vudoo Avid S4/S6 3 05-30-2018 03:06 PM
