Old 11-20-2009, 11:59 AM
heavymoe heavymoe is offline
Default Amp Farm / Echo Farm Stop Passing Signal
On one of my PT HD 7.2 CS2 rigs running both Amp Farm 3.10 and Echo Farm 2.30, each will stop passing signal until re-instantiated. I have found a few references to this bug on other threads, but have been unable to find an documentation on a solution. I am assuming that this is a DSP mangler (oops, I mean DSP Manager) issue, but I can't not add plugs or change voicing after adding one of the plugs. Anyone have a solution?
THANKS!
Old 11-21-2009, 09:54 AM
scottgreiner scottgreiner is offline
Default Re: Amp Farm / Echo Farm Stop Passing Signal
Sorry to say, it's a well know issue, and it's doubtful that anything will be done about it. From what I understand, these are more or less Line 6 products. They're on to other things and can't be bothered, and the Digi engineers most likely have bigger fish to fry. They've already stated somewhere that Ampfarm would no longer be supported and you could buy some clunky Line 6 widget at a discount. Or buy Eleven.
Just make it part of your mix routine to check all instances of these plugs. I put a note in the comments field... or print the tracks...
Old 11-23-2009, 02:29 PM
c-tone c-tone is offline
I just had this problem for the first time today. I think it only cropped up after I upgraded my computer to Mac Pro / Leopard and 7.4.2, because I never saw this issue under 7.4 and Tiger on my G5.
www.clifnorrell.com
Old 11-24-2009, 10:00 AM
Me too, but that was a year and a half ago...
Personally, I gave up keeping score with what got fixed and what got re-broken. I just find a work-around and keep going. Digi can't keep track of Digi, so I certainly cant. Most of these annoyances aren't deal-breakers for me (but the "midi placement with ADC" issue is pretty close).
Echo Farm and Amp Farm TDM x9blade Buy & Sell 0 12-22-2013 06:16 AM
Echo Farm mastert Pro Tools TDM Systems (Mac) 5 05-26-2010 08:22 AM
See ya later ECHO FARM, meet POD FARM 2. EvilElfBoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-31-2010 09:36 PM
Echo Farm and cs8 McMasters Pro Tools TDM Systems (Mac) 3 03-21-2005 04:15 AM
Echo Farm bug? uno1234 Pro Tools TDM Systems (Mac) 1 02-25-2005 02:50 PM
