Re: Protools 11.2.1 and 11.2.2 unable to detect Eleven Rack
That doesn't make the driver appear in Programs & Features - but looking through I just came across this message. "Windows has detected that audio enhancements for the following device are causing problems: Speakers (Avid Eleven Rack). Would you like to disable Driver Enhancements for this device?"
Any thoughts on what that means? |
Are you trying to use the Eleven Rack as the sound card for your computer? I would disable that. We need to start fresh. Go to Device Manager> Sound, video, and game controllers Do you see AVID ELEVEN RACK listed? If not, the driver is not installed. Go to VIEW>Show Hidden Items and re-check, do you see Avid Eleven Rack anywhere? Have you tried scf /scannow to check for any bad system files? What about error checking the hard drive? And you have tried other USB ports? are these USB1, USB2, or USB3 ports? Are you using a hub or directly into the computer?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I just checked View Hidden Items and Eleven rack appears twice. I am going straight into the computer and I believe they are USB3 ports. I'll try another port. Should I uninstall one the Eleven Racks?
https://www.youtube.com/watch?v=1dl0pFgkRyE and/or this blog post: http://elevenrackusers.blogspot.com/...-part-1-2.html However, your main problem is probably that you are using USB3 ports. Try a USB 2 port.
#16
{Unable to Load Device Driver} %hs device driver could not be loaded. Error Status was 0x%x When I try to update drivers through that window it says the latest drivers are installed, but there are no drivers installed! Also, Eleven rack Firmware version is 2.0.1, build 0.1.5.7 |
#17
You are on Windows 8.1 right? Have you considered doing a refresh of the PC? There may be something corrupt that is preventing the driver to install. I don't know what you have on your system so be sure to read up on the procedure first and make sure you have everything you need to authorize programs that will be erased during a refresh. Other things would be check with the manufacturer website and see if there are any BIOS updates or driver updates, or chipset updates.
#18
I am trying to avoid the system refresh until it's a matter of last resort for the reason that I'm sure I'll miss some password or other for something |
#20
unable to control eleven rack with rocktron midi mate | imemy | Eleven Rack | 8 | 04-12-2013 04:31 PM |
Pro Tool LE 8.0.4- Unable to detect digidesign hardware? | Bluejaye | Windows | 9 | 04-07-2013 08:24 AM |
Pro Tools unable to detect Mbox 2 | KangarooOne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-04-2013 06:49 PM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Unable to detect digi 002 AND 003, multiple systems. | Drumattacks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-04-2010 09:45 PM |
