Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 02-22-2020, 10:10 AM
Elton Hyland Elton Hyland is offline
Default About to take the leap. Your thoughts?
I moved my studio from Washington State to Nashville. While out west, I used PT7 etc. With that, I also used a Command 8, 003 RACK. The COMMAND 8 being USB and the 003 being Firewire.
After reading about compatibility, I am understanding that
1. The 003 RACK is still supported with the latest PT version.
and
2. The Cmd8 is NOT supported but still works.
QUESTION: If I upgrade to the latest PT, do you think I will have any issues? Or should I try to get a version like 10 or 11?
Thanks
WinXP Pro. 003 Rack, Command 8. Alesis Powered Monitors, Roland XP80 Kbd. Dual core 1.8 w/ 2 Gigs RAM
Old 02-23-2020, 10:58 AM
smurfyou smurfyou is offline
Default Re: About to take the leap. Your thoughts?
I thought it was the other way around. 003 Not supported, Command 8 is supported. At least it's still there in the Peripheral setup as an option and mine works fine. It is definitely EOL with no tech support but the software still supports it.
~Will
Old 02-25-2020, 04:26 PM
AFAIK, both are not supported, but both still work with even the very latest PT(running a 003rack on Windows 10 with PT2019.12 here). In Nashville, you probably will need more inputs so plan to add an 8-channel lightpipe preamp to your setup. The Behringer ADA8200(the red one at around $200) is a great budget option. The Midas XL48(around $879) is absolutely killer on drums! I did a lot of recording in Nashville with 003, a lightpipe preamp and a DBX386 on SPDIF for 18 inputs Also, you'll need a way to get some good headphone mixes(happy players make better music)
Leap ! By Leap Motion ! ! ! AVID!?!? This gonna work???? Table Syrup Records General Discussion 22 07-20-2012 12:12 PM
8.0.3/snow leap jackandrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-25-2009 10:06 AM
Thinking of leap from LE to TDM DodgeSongs Pro Tools TDM Systems (Mac) 8 10-23-2006 10:46 AM
G4 upgrades...or the big leap? joshua d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-22-2006 04:05 PM
Making the OSX leap johnnyreno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-20-2003 10:58 AM
