Re-Mapping VI's after PT Upgrade
Hello,
I've upgraded to PT12 from PT10. I'm starting to open older sessions from PT10 onto the newer PT12. Everything seems to be opening up fine... However, looks like the virtual instruments need to be re-mapped since I used many VSTs from SampleTank and such. My question is: how do I know exactly which sound was used on a specific VI layer in the PT session? For example, all I see now when I click on the layer is the name of the VI library (in this case SampleTank 2.x) along with the message "plug-in inactive" I understand that I'll have to use BlueCat Audio or something of the like in order to use VSTs in PT12. That's no problem. I just was wondering if there is an easy way to figure out exactly what sound within the older VST library was used on each layer so that I can successfully replace that sound with its identical one in BlueCat Audio. I realize that one way to go about it is to open up each session file in PT10 and write down the exact sound that was used then go back to PT12 and plug in that sound. Just wondering if there is an easier way that I can see directly from PT12 without having to go back and forth between versions? Thanks in advance! |
Re: Re-Mapping VI's after PT Upgrade
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Donald, thank you! I will try that and report back if it works. I didn't know I could have pt10 and pt12 open simultaneously. I thought my pt10 license would be surrendered at time of upgrade. But then I realized the upgrade is for 10, 11 and 12. Good to know I can download both for this VI replacing process. I'll try it out. Thanks again!
As Donald said - make a User Preset - "Save Setting As" in Pro Tools 10. Close Pro Tools 10. Open Pro Tools 12. Instantiate Plug-In and select your User Preset.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
DB 33 Mapping | GTBannah | Windows | 0 | 03-23-2011 04:16 AM |
Tempo Mapping | KingStudios | Pro Tools M-Powered (Mac) | 0 | 06-05-2008 01:50 PM |
Mapping Mapping Mapping! Please Digi, Hear Us... | relaxo | MIDI | 0 | 11-03-2005 09:44 AM |
Key Mapping?? | HiRaX | MIDI | 0 | 02-27-2003 12:20 AM |
mapping through 001 | Andy001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2002 05:39 PM |
