Pro control monitor board upgrades....
Hey.
I know this is a dead horse, but....I emailed and faxed a list of my procontrol serial numbers into support(per their instructions). I was informed that I would recieve my monitor board upgrades soon. I have not recieved them yet. That was a long time ago. March 26th to be exact. Has this process taken this long for other users? Kelly L.
Kelly Lichtenwaldt [email protected] Pro Tools System administrator KUBE FM, KBTB FM, KHHO AM, KJR AM, KFNK FM |
Re: Pro control monitor board upgrades....
All were under 'warranty'. All 5. Still silly that is even considered an issue. The ProControl monitor section sounds horrid, and should be fixed. Digi offered a solution. I applaud that. But paying for it? crazy. If they were not under 'warranty', I would be sending them back. A control surface of that quality should not be having L-R image/level issues. If it does, a timely card replacememt/mod should happen. No big deal. No big deal to do in the field, either. But to say it is an 'upgrade' just kills me. On top of that....I still don't have my 'warranty upgrade'! If someone from Digi sees this, go ahead and send those upgrades to:
Kelly Lichtenwaldt NCM Engineering Suite 300 351 Elliott ave w Seattle, WA 98119. 206.494.2310
Just curious, did you pay for the 'upgrade' and was your PC still under 'warranty'.
Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015) Monterey 12.6.8 64 GB RAM 1 TB PCIe flash storage Pro Tools Ultimate HD 2023.6 HD Native Thunderbolt |
Hi NCM engineering,
You Said: "The ProControl monitor section sounds horrid, and should be fixed". Response: The analog board upgrade does not change the "sound quality" or sonic characteristics of the analog section. Analog Board upgrade: Clickless switching for Mute, Solo, Dim, and Alt Improved Crosstalk Redesigned headphone amp circuit (more signal, less distortion). You also said: A control surface of that quality should not be having L-R image/level issues. If it does, a timely card replacememt/mod should happen. Response: Addressed in March of this year, any boards or upgrades shipped since then meet the new spec. The new spec is +/- 1 dB between channels in the stereo pair, between 9 o'clock and 3 o'clock. The old spec was +/- 3dB. We have screened pots available as Outbound Shipments ("part, ProControl Main Pot") from CS/TS. If you have your monitoring system set so that 9 o'clock is the bottom of the spectrum then there will be no audible difference between L/R. MJ Digidesign Tech Support [This message has been edited by TechSupt (edited June 12, 2001).] |
MJ: You replied,
"The analog board upgrade does not change the "sound quality" or sonic characteristics of the analog section. Analog Board upgrade: Clickless switching for Mute, Solo, Dim, and Alt Improved Crosstalk Redesigned headphone amp circuit (more signal, less distortion)." My PC is out of warranty. The clicking switches and rotten headphone amp are pretty brutal and obnoxious. I'm still trying to understand why the fix is an 'upgrade' and not a 'recall'. I feel Digi should replace those monitor boards free of charge since they were defective to begin with. There are no real 'new' features, it just FIXES the original problem. I love the PC, but to have to pay to fix the defective switches on a 12k console is embarrassing. Could you respond to this? Thank you.
Sad story for me too...
( http://duc.digidesign.com/cgi-bin/ul...&f=29&t=000269 ) Anyway, I called Digi and after bouncing for almost 45 minutes between different people I gave all of my details to a gentleman who said he would have faxed to me some papers to fill in and sign and fax back which are necessary in order to receive the "upgrade"... No fax received yet!!! Digi? My name is Enrico Donner and my fax number is (284) 494-9803
1x Pro Tools HDX 3x Pro Tools HD3 MCI JH-528, Harrison 950MX, 2x Dangerous 2BUS 2x Crane Songs Trakkers, API 2500, Manley Vari Mu, Manley ELOP, Elysia Xpressor Manley Massive-Passive, Elysia XFilter Lexicon PCM 70, Lexicon PCM 60, Yamaha SPX2000, Yamaha SPX990, 2x Line6 Echo Pro http://www.enricodonner.com http://www.karmalunastudios.com http://www.donnermanagement.com |
I would just like my monitor board "upgrades".
I have faxed my serial numbers to Jordan in tech support, and have not recieved any monitor board upgrades yet. That was 2 months ago. On the other issues'... <<<<<<<<<The analog board upgrade does not change the "sound quality" or sonic characteristics of the analog section. Analog Board upgrade: Clickless switching for Mute, Solo, Dim, and Alt Improved Crosstalk Redesigned headphone amp circuit (more signal, less distortion).>>>>>>. What, clicking,poping and cross-talk are not sonic characteristics of a monitor section? Damn right i am upset. I just want non clicking-poping monitor sections, and a monitor knob that gently fades the left side and the right side down at the same level. That is an easy fix. It sounds like digi has come up with a solution, and has implemented that soulution. A new monitor section, and a screened monitor pot. To be charged for it is an insult. Again, please send a total of 5 monitor section re-call kits to: Kelly Lichtenwaldt NCM Engineering Suite 300 351 Elliott ave w Seattle, WA 98119. 206.494.2310
We paid for the upgrade in January. Got it in 3 weeks. Then...filled out the request for the new stereo "POT" online.....and recieved it in 4 days. Monitoring seems fine now. We are an AVID Authorized Education Center for Pro Tools....I don't think that had any impact on the timing though....
Rob |
NCM (kelly)
Upon further investigation, it appears that of your (5) Procontrols, only (1) is a KH serial number having the old analog board. The other (4) have NX serial numbers and are current shipping hardware (new analog board, connectors, main pot). As per Jordan, viewing his call record, he provided you with that information and was waiting for a return call with the payment information so he could process your order for the one Procontrol. I provided you with information on the analog section and a link to the Procontrol product managers post on this very topic. It is detailed and explains Digidesigns view on this issue ( So please take a minute to check it out ) .I have attempted to call you at the phone number provided but only got voicemail. If you post a good time to call you then we can go from there. Hope this helps. MJ Digidesign Tech Support |
Can I still swap out a monitor board / power supply for control 24 | Gordon Hookailo | ICON & C|24 | 5 | 05-11-2012 08:32 AM |
Profile as a monitor Board | wolvesandi | VENUE Live Sound Systems | 7 | 01-08-2011 05:15 PM |
Hum and DC from center monitor. Anyone know if it's the PS or Monitor board? | Gordon Hookailo | ICON & C|24 | 2 | 12-18-2010 01:42 AM |
Monitor and Mic Pre Upgrades | Mike Landolt | ICON & C|24 | 0 | 10-14-2006 06:49 AM |
Monitor Board "Upgrade" | bairtracks | ProControl, Control|24, Command|8 | 30 | 04-01-2001 03:35 PM |
