Fine volume adjustment
I cannot get the fine volume adjustment to work. I used to be able to command-click a breakpoint with the grabber tool and do fine adjustments in .1 db increments but it will not work. I have tried command-click and click-command and neither work. I have also trashed all the preferences and restarted and it still doesn't work. Any help with this issue would be appreciated.
Thanks System config Dual 2ghz PowerPC G5 10.3.8 OS PT vers 6.9.1cs3 2 gig of RAM |
Re: Fine volume adjustment
Regarding the Fine Level adjustment.... for Volume. Command - Click on the breakpoint to do fine volume adjustments in .1 db steps works fine in PT 7.1cs6 and OSX 10.4.6 I believe it has always worked this way since PT 6.x The upgrades to PT 7.1 and OSX 10.4.x are well worth it. So you might want to consider that. Or you may want wait until Digi releases PT 7.2 to upgrade.
As far as I can tell it should be working on your system. I'm sure you know about all the usual stuff like trashing Prefs and all that. If you have already tried that. Try a complete Re-Install of your PT program. Let us know how it goes....... |
Well I ended up repairing permissions and now it works correctly. i had a problem repairing permissions and found in the apple support site that a known bug existed in 10.3.8 in repairing permissions and it gave the work around for it. Everything works as it should now. I already have the update to 7.1 and will be updating everything next week when I finish my current project.
Thanks for the advise. |
Audition/Preview volume adjustment? | Farmer Dave | Pro Tools TDM Systems (Mac) | 5 | 06-27-2013 03:31 PM |
Fine Adjustment on AAX seems to be Broken? | Neil Pickles | AAX Plug-ins | 4 | 06-07-2013 01:39 PM |
Volume Adjustment | tboneman1960 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-16-2013 01:46 AM |
fine adjustment of breakpoints not working | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-03-2010 06:42 AM |
Strip Silence and Fine Adjustment... Still a bug? | SimpleNatureSpirit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2004 11:22 PM |
