Old 03-29-2013, 06:39 PM
mikevarela mikevarela is offline
Default the current playback engine does not support a sample rate of 47.9 kHz
getting this error when opening a PT5 session. Happens on HD and non-HD systems alike. Can't get past the error.
Thought it was conflict between Pro Tools Aggregate and mac/PT using different soundcards. Not true.
I've dumped databases and deleted the PT Aggregate from Audio/Midi setup and still not working.
Any help out there.
File Type: png Screen shot 2013-03-29 at 6.36.42 PM.png (17.4 KB, 18 views)
NuanceTone.com
Old 03-29-2013, 06:48 PM
Dism Dism is offline
Default Re: the current playback engine does not support a sample rate of 47.9 kHz
Any help out there.
Opening a PT5 session in what version?
Have you tried creating a new session and using Import Session Data? I find the particularly old sessions can be touch and go, especially since they are usually using tools and plugins that don't exist anymore. ISD often helps.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-30-2013, 08:33 AM
Kasper Kasper is offline
Is it possible the session was pulled-down to 47.952?
Try creating a new session and importing data from this one, as Dan suggests.
kasper
Old 03-30-2013, 09:26 AM
lexaudio lexaudio is offline
Try creating a new session, setting if for pull down, 29.97 .01 percent pulldown and import the session
HTML code is On
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
The Current Playback Engine Does Not Support A Sample Rate of 44.1Khz ZiviMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2013 02:05 PM
The current playback engine does not support a sample rate of 192k Oblivious74 macOS 3 06-01-2011 07:08 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
