002 optical inputs
I have an Apogee Ensemble in stand alone mode with optical out to optical in on a 002. Pro Tools 10 software. No signal is showing up in pro tools. Suggestions??
Thanks |
Re: 002 optical inputs
A few things to check:
Apogee set to either 44.1 or 48K(002/003 can't handle higher on lightpipe) (in PT) Setup>IO>Input tab-are the ADAT inputs enabled(9 thru 16)? (in PT) Hardware>is the optical in set to ADAT(and NOT SPDIF)? (same place) set Clock Source to Optical Lightpipe "cable" seated well at both ends?(its kind of a crappy connector)
thanks for the info.
I now have audio going into pro tools thru the 002. Should I be able to input all 8 channels of the ensemble simultaneously? I am only getting ADAT 1 & 2. Any suggestions?? |
Yes you should be able to track them all simultaneously. Is ADAT 1&2 the only input option you are getting? Should be able to cycle through ADAT 1-8 and be hearing audio on each (as long as there is input sources on each obviously).
Maybe this will help. I follow the instructions given to me by Apogee yesterday to put the ensemble into stand alone mode. But when I unplug the firewire to the ensemble, as instructed, I lose all signal sent to the 002. If I leave the ensemble firewire plugged in, I can go to the mixer in Maestro and send signal to the 002/pro tools but only Adat 1-2. I know it's a setting somewhere but I'm at a loss to find it. Frustrating
Mike |
192 io optical inputs | ynor | Pro Tools TDM Systems (Win) | 1 | 02-05-2011 06:06 PM |
Optical / adat inputs, help | songman0412 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 05-10-2007 04:48 AM |
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? | el biciclista | Pro Tools TDM Systems (Mac) | 2 | 07-09-2002 10:32 AM |
Optical Inputs | HSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-01-2001 06:49 PM |
analog & optical inputs together | tracks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-17-2001 06:47 AM |
