Old 12-27-2012, 03:22 PM
fretcruiser fretcruiser is offline
Default 3/4 outputs not available in MP9.
Guys, I just picked up the FastTrackC400 to replace my fasttrack usb. I'm running into a bit of an issue. From what I understand the headphone volume is correlated to the 1/2 outputs. I connected the 3/4 outputs from the FTC to my speakers so I can have a headphone mix and a mix to the speakers.
My problem is that Outputs 3/4 are not available to select in Pro Tools. When I look in the Hardware settings, 3 and 4 are in there. But when I try to send from a track, only 1/2 appear. Any ideas?
Old 12-27-2012, 03:34 PM
Default Re: 3/4 outputs not available in MP9.
Have you been to Setup>IO>Output tab and hit the DEFAULT button? Or can you simply add the path for 3&4? Learning how(and why) to setup the IO can really make your life easier
Old 12-27-2012, 03:53 PM
Yessir. That helped. I'm learning how to use PT after spending years with Reaper, so there's a steep learning curve.
On a side note, is there a way to change the headphone routing to cover the 3/4 output rather than the 1/2 with the C400? This would make my life a whole lot easier too.
Old 12-27-2012, 07:48 PM
Not positive as I don't own that box, but I would consider a small headphone amp and feed it from the 3&4 outputs. Then, set up a stereo AUX send that feeds outputs 3&4. If you make the sends Pre-Fader, then you can create a completely independent headphone mix for the performer, and then the engineer can adjust the main mix or solo/mute stuff at will, and not distract the performer
Old 05-24-2013, 05:49 PM
rmsyster rmsyster is offline
Did you managed to setup output 3 and 4? I have the same problem. I don't know much about it. Can you tell me what steps you made to use outpur 3 and 4? I made it work on my windows xp and 7 but it's not working on mountain lion. Please advice. Thx!
Old 05-24-2013, 05:50 PM
I am using Pro Tools Fasttrack Pro
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! italianguitar Eleven Rack 15 03-20-2012 01:57 PM
Apogee Duet outputs better sounding than Digi002R outputs? Pasz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 02:19 AM
please help on mirroring outputs 1-2 to s/pdif outputs! ournature 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-13-2007 08:52 PM
Outputs not available BassGimp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-19-2006 08:31 PM
