Stereo Interleaved vs Multi Mono
a young girl i produce is putting a backing band together and the drummer has asked for click on the left track and backing vocals, strings and other stuff the band doesn't play on the right track
i panned everything and did an export (not bounce) in stereo mode i'm getting cross talk on the click track but when i solo the click in the session it has no cross talk and it should not because it is a looped 1 bar song length file that i know has no bleed on it. multi mono does not have any bleed when i play those files discreetly in quicktime to check outside of PT why is stereo interleaved having this cross talk issue stereo interleaved is my file format of choice as i don't currently have software that will burn multi mono like some out there i'm using toast. why is this happening?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Re: Stereo Interleaved vs Multi Mono
One part that I am not understanding. If you are doing an export, are you mixing your tracks down to a printed stereo track with all of these settings and then exporting the track?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Also, have you checked to make sure that it isn't Toast that is causing the problems? Toast has been one of my buggiest programs I have ever owned. I would first try burning it in iTunes or something else and make sure that the problem is completely related to Pro Tools.
Because you're listening in iTunes/iPod and Sound Enhancer is turned on.
"stereo interleaved is my file format of choice as i don't currently have software that will burn multi mono"
that's one of the reasons i keep my old copy of jam around... even though toast absorbed most of jam's features they left that one out. b.o.l. e
ihatetyping |
As a work around try this. Make your 2 mono tracks then give both tracks the same name and add to the name ".L" on one and .R" on the other. If you select the left track in Toast, Toast will pick up the ".R" or right track as if it were a stereo file. At least Jam will do that.
my money is on this... let us know.
no no no
my issue is NOT toast related it is the file itself is bleeding / cross talking after doing the interleaved stereo file option in export i'm actually hosting the file on my server to the drummer it never gets to toast what i said was i use toast normally to burn cds and use the interleaved format as i don't think it can bring in the other side like old digi masterlist could my issue is in the export bleed not a burn format
perhaps i'll try jam but as i say i'm not trying to burn a CD my hope was to have an interleaved stereo file that does not have any crosstalk into the left channel click track channel the drummer can take the bleed for some reason even thought the stuff on the bleed is going through the P.A. bottom line the left channel should be discreetly clean of anything from the right channel and that is not happening AFTER i make the export interleaved conversion
but that doesn't matter the drummer is getting crosstalk on the files i sent him i can hear it too.
PT exports stereo interleaved AND multiple mono - why?? | jkatcher | macOS | 5 | 06-25-2015 04:46 AM |
stereo interleaved or multiple mono to send for pre-master? | grendizer | Pro Tools 10 | 15 | 12-15-2011 03:26 AM |
when do I bounce multi mono versus interleaved???? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-08-2007 12:55 PM |
Converting multiple mono to stereo interleaved | danielpetry | Tips & Tricks | 1 | 01-05-2007 08:58 PM |
mono to multi mono or stereo? | Dean Smith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-21-2006 02:32 PM |
