Digi - What bits are cut off on the LE systems that aren\'t on the TDM systems?
Ok so now I am totally confused about the whole bit depth thing with pro-tools. Acording to This digizine article the mix buss should have a minimum of 36 bits? So what bits are cut off on the LE system.
Then again to further confuse you. How is it that you can say that you have to have 36 bits then come back with This Answer Base Responce saying that we have better bit depth than the TDM systems? Is there a Scaling of audio that is going on here? Am I the only one confused about this? [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] |
Re: Digi - What bits are cut off on the LE systems that aren\'t on the TDM systems?
It's just the "itty" bits that are cut off. Itty bits are those caught bussing without a crosstown pass.
Hope this helps.
Esteban WB |
Those crrrrrrraaazzzyyy bits. [img]images/icons/grin.gif[/img]
Buying used TDM systems from Digi? | PTGuy | Pro Tools TDM Systems (Mac) | 22 | 06-06-2007 11:50 AM |
Anybody using 2x DIgi 002 systems (2Macs) ? | Re_Org | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-27-2004 10:37 AM |
Digi, when will mix systems have DV support? | Boom Chic | Pro Tools TDM Systems (Mac) | 19 | 11-15-2002 12:58 AM |
Digi to Dump Mix Systems !!!! | Kenny Gioia | Pro Tools TDM Systems (Mac) | 43 | 08-16-2002 12:04 AM |
How many Digi 001 systems are out there? | Freshington | General Discussion | 10 | 01-04-2002 03:21 AM |
