Old 08-22-2013, 10:53 AM
audiofreak11 audiofreak11 is offline
Default "Could not complete your request because basic_string..."
I can't figure out what's happening with my Pro Tools system and am hoping someone might have some insight. It started while on ProTools 10.3.6
Approximately 7 times out of 10 over the last few days, when trying to launch Pro Tools, it returns with an error, which I've attached screenshots of here.
"Could not complete your request because basic_string::_S_create."
I click OK and get a second message, also attached. When clicking Ok on the second message, the dialogue box just blinks and stays there. It keeps coming back up, and I can't open Pro Tools. I have to Force Quit in order to close it out.
I've used disk utility to repair my hard drive and it worked once. I also upgraded from 10.3.6 to 10.3.7 and that worked once when opening 10.3.7, but now I still get these errors. I uninstalled 10.3.7 in safe mode and reinstalled and still get the errors.
I DO have Pro Tools 11 on my Mac as well, but I don't use it just yet.
Wondering if you have any thoughts on what might be happening, and any suggestions?
Thank you so much!
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Intel iMac 3.4GHz i7 (late 2012) with 32GB RAM
Digi 003r
Old 08-22-2013, 11:14 AM
Default Re: "Could not complete your request because basic_string..."
Just as a follow up, I repaired disk permissions again and now ProTools is working. Other times when I repair disk permissions, it doesn't work. All it repaired were some itunes things and internet plug in things.
I wanted to add this piece of info, in case it helps you help me. The inconsistency is bothersome.
Regards,
Chris
ProTools 12.7
Mac OSX 10.12.2
Digi 003r
"Could not complete your request because Access is denied" ColinSound Windows 2 05-13-2013 02:58 PM
FIXED: Startup issue: "Could not complete request because Assertion line 1424" wheret Windows 2 07-11-2012 05:43 PM
Error message "could not complete your request because..." on PTLE 8.0.3 load up blast9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2010 02:49 PM
"could not complete your request because end of stream encountered" PT8 promblem nikokarpaasi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-22-2009 12:49 AM
"Cannot complete request... Access violation occured" jonnyb8390 Pro Tools TDM Systems (Mac) 0 01-07-2009 12:39 PM
