Old 02-18-2008, 08:08 AM
tamasdragon tamasdragon is offline
Default Waveforms not shown during recording
Suddenly I cannot see the waveforms during recording. I'm not in loop or punch or destructive mode, so cannot really understand what happened.
Tamas Dragon
my blog:Tamas Dragon
Old 02-18-2008, 11:47 AM
Default Re: Waveforms not shown during recording
The situation is wierd. One machine with dualboot, identical xp, identical pt. On the a xp waveform are drawn as I record, on the b xp waveforms are not drawn during recording, only after pressing stop. Record mode is normal. How can I solve this?
Tamas Dragon
Old 02-18-2008, 12:12 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Tamas Dragon
are all your preferences set up indentically on each system??? how do you have scrolling setup??
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 02-18-2008, 03:58 PM
Kirby B. Kirby B. is offline
I had this happen recently too for the last days I had 7.3.1. It went away after I just went to 7.4cs2, but it was strange as I couldn't check if it was really recording.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 02-19-2008, 03:15 AM
Every parameter is identical in the prefs, scrolling is set to page at both profile. Really cannot understand what's happening. Even the plugs are the same.
Tamas Dragon
Old 02-19-2008, 06:36 AM
Third Eye Studios Third Eye Studios is offline
Are you using low latency monitoring? If so try turning it off to see if the waveforms are displayed.
Old 02-19-2008, 11:45 AM
Tried in low latency, tried when it's off, tried with different buffers too, but still no sucess.
I suspect that I should reinstall protools in that system.
Tamas Dragon
Old 02-20-2008, 01:58 AM
Ok, an update. For the record, this machine has 4GB ram, and protoolsle is patched with largeaddressaware. If I remove the patch, everything is working (drawing the waveform during rec), and as soon as I apply the patch, it doesn't draw the waveform.
Now the funny thing is that, at the other profile I patched the file and still draws the waveform during rec. Now I really don't know what can be the solution.
It's not that I cannot live without the patched protools, but now at this point I really want to know what cause this that in profile a everything is fine, and the in profile b (which is identical to a) it causes problem. I checked that the two windows are having the same updated components, even has the same videocard driver, so now I seem to have no idea what can make this thing work in one profile, and make bad in the other.
Still wait for any expert to chime in.
Tamas Dragon
I can't see the waveforms while recording...! Joemamma Pro Tools M-Powered (Win) 4 10-29-2015 06:18 PM
Any way to display waveforms as you're recording? Undertones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-18-2010 03:45 PM
Not drawing waveforms while recording zoggied Tips & Tricks 2 11-07-2002 05:24 PM
How come I can't see waveforms while recording? ckevperry Pro Tools TDM Systems (Mac) 3 02-12-2001 07:05 PM
render waveforms while recording jaglance Pro Tools TDM Systems (Mac) 4 07-06-2000 07:50 PM
