Re: AVID HD I/O Analog not showing in peripherals...
Yes a HD IO works by itself, two people here would not be telling you to try that if it did not. Especially with DigiLink systems when there are problems reduce the system to be bare minimum to test.
Not sure what you mean about the 192. You can combine a 192 IO with a HD IO or Omni IO or anything else as long as you stay within the DigiliLink connection capabilities. But none of this matters, the box does not pass Digitest stand alone... so return it. |
Be that as it may be, I returned the DOA unit and that has now been replaced with a working unit. All tests OK now. Thanks for all the input! Much appreciated.
Apple Mac Studio M2 MAX, 10 core, 96Gb RAM, 1Tb HD, macOS Ventura 13.4, Pro Tools 2024.3, AVID Omni HD, 2x AVID I/O, 1x HDX, Sonnet Tech Echo Express III-D (Thunderbolt 3 Edition), UAD-2 OCTO PCIe. |
Avid Application Manager not showing all Avid Plugins | quincy_j_clomo | Licensing & Accounts | 1 | 01-19-2018 09:18 AM |
MIDI device not showing up in peripherals | nibtgom | Pro Tools 11 | 1 | 09-19-2017 11:59 PM |
Avid X-Form 12.0 not showing up in 12 | audiobob | Pro Tools 12 | 5 | 11-17-2015 04:22 PM |
Avid Pre Not showing up in AMS | rsandifer | Pro Tools HDX & HD Native Systems (Mac) | 2 | 06-30-2014 04:03 PM |
Analog inputs 9-16 showing up in Hardware, not in I/O? | voidmix | Pro Tools HDX & HD Native Systems (Mac) | 8 | 09-25-2012 07:06 PM |
