Eleven Rack/003 set up problem?
Hi all,
I’m having a problem with recording through my Eleven rack into pro tools LE8. I have loaded all updates for PT and firmware for 11R. This is probably something simple, but sometimes simple things stump me : ) I have my guitar plugged into True z input and can hear it fine when I have headphones plugged into jack on 11R…sounds great. Now I want to record into PT. I open up a new session and select 11R for track input and Main outs for track output, record enable…but I get no signal, no meter reading. Input on 11R is Guitar and also have Rig Input and Rig Output I believe it is?? Am I meant to have a spdif connection from back of 11R to back of 003 for this to work? Or is there a setting on the 11R hardware that I need to know about? I was hoping someone could post a step by step guide on how to set up so I can record with 11R and PTLE8/003…I’m sure it’s something simple and believe I’m just missing something obvious here… Hope you guys can help.
Pro Tools LE 8 003R+, Macbook Pro 13", M-Audio Profire 2626, Eleven Rack |
Re: Eleven Rack/003 set up problem?
When you have another Digidesign/Avid interface hooked up to the same Computer "IT" will normally default to being the main interface for Pro Tools and the Eleven Rack become like any other piece of outboard gear, meaning that when another interface is connected, no longer does Audio flow through the USB cable of the 11R, only information that provides you with the Eleven Rack Window in Pro Tools. If only the 11R is hooked up then the Audio will flow through the USB cable of the 11R.
So as you can see, if you have a 003 hooked up, and it is set as your Pro Tools Engine, therefor Audio is not coming through the 11R USB cable, so you need a way to get the audio from the 11R to the 003. You could just use the main outs run in to the 003, but SPDIF would be best in this case. So here is a video detailing that with an 003R: Eleven Rack Tutorial - Hook Up To Another Interface With S/PDIF and instructions to Re-Amp when using another interface (not the 11r) as your Main Interface Eleven Rack Tutorial - Re-Amping With S/PDIF Part 1 Eleven Rack Tutorial - Re-Amping With S/PDIF Part 2 Eleven Rack Tutorial - Re-Amping With S/PDIF Part 3
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Win 7, PT 9, 11 rack, superior drummer 2.2, Gibson guitars, yamaha bass, Dimebag washburn
Eleven Rack + ERXP Pro Tools 9 Windows 7 Gibson Guitars Washburn Guitars Michael Kelly Guitars Yamaha Bass Roland TD30K EZ Drummer 2 Superior Drummer 2.2 |
Thanks for the reply guys.
Benoni, well you touched on it...master/slave type thing. That's what it was, i just needed to set the playback engine in the 003 to 'Eleven Rack'...stoopid!! - There was a similiar thread RE: this prob as well, didn't spot it though till later... Unless your doing this stuff on a constant basis, it sometimes slips your mind to check things like that, so thats all it was...I will know start to play around with it some more and see where I end up. Looking forward to getting stuck into the ol' 11R! Thanks again guys for your prompt replies...great forum this...many helping hands! Will definitely check out the tutorials too...good stuff Pete
eleven rack - problem | hydra | Eleven Rack | 2 | 10-05-2012 01:12 PM |
Eleven Rack Problem | adflaker | Windows | 3 | 11-09-2011 02:27 PM |
Eleven Rack Monitor problem | fustrun | Eleven Rack | 1 | 06-10-2011 06:02 PM |
Eleven Rack Delay PROBLEM HELP!!!! | zenabi916 | Eleven Rack | 2 | 11-06-2010 07:52 PM |
Eleven Rack Problem | Päng | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2010 12:54 AM |
