Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 07-27-2017, 08:21 PM
dancecadaverous dancecadaverous is offline
Default Can't Open Pro Tools First
I bought a 2007 iMac (specs below) off a coworker so I could run Pro Tools on a bigger display for my home studio. Downloaded an older version of Pro Tools First (whatever version was right before 12.8, not sure exactly). It ran fine.
Then I updated to 12.8 and now it simply won't start on my machine. The splash screen will load, but it will freeze halfway through and then when I right click the icon I get "application not responding." My system requirements check out, I'm running a 2nd gen MBox mini which is old but shouldn't prevent the app from at least opening right?
I can't update to OS Sierra but that shouldn't be a problem as the system req's list El Capitan as a compatible OS. Can anyone help? I want to get back to my sessions!!
2007 iMac
OS X El Capitan 10.11.6
2.4 GHz Intel Core 2 Duo
4 GB 667 MHz DDR2 SDRAM
Pro Tools First 12.8.0.865
2011 Macbook Air
macOS Sierra 10.12.1
1.7 GHz Intel Core i5
4GB 1333 MHz DDR3
Pro Tools Express 10.3.4.181
Audio interface: MBox Mini 2nd Gen
Old 07-28-2017, 12:24 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Can't Open Pro Tools First
Try holding down the N key while Pro Tools loads. This will force a hardware refresh, which will hopefully get you past the splash screen and will allow you to choose the playback engine settings.
Will
System Details
How do I open older Pro Tools Sessions on newer Pro Tools systems? Michaelnacho Pro Tools 11 7 08-06-2021 08:36 AM
Pro Tools 11 doesn't work,Sesions open then pro tools stop responding tronic21 Pro Tools 11 6 07-31-2015 02:27 AM
Can I open projects saved in Pro Tools 8 within Pro Tools 11? jenniemay2013 macOS 3 12-27-2013 06:48 AM
Pro Tools 9.0 and 9.2 do not open plz help 10 blue screen crashed due to Pro Tools shamanrock Windows 21 04-04-2011 03:26 AM
Pro Tools HD 7.4 zipped Session wont open in Pro Tools SE Lyvewire Pro Tools SE and Essential (Mac) 3 03-01-2011 04:41 PM
