Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 05-17-2017, 12:47 PM
Balanced Jack Balanced Jack is offline
Default MBox Pro v3 with External Mic Pre's
I'm plugging my external pre's (Avalon 737 SP's x2 & Vintech X73i's x 2) into balanced line inputs 1-4 on the rear of the MBox Pro. All connections are correct, switched to line inputs, +4 switches are engaged, rear inputs selected, inputs are gained all the way down. The levels are ridiculously hot hitting the MBox. Compared to inputting the pre's into an Apogee Rosetta, I'm having to turn the input and output of the pres's down to about 1/4 of what I'd usually run them at to hit approx -18dbfs using sample peak meters in PT12.7.1 on Sierra. Anyone else experienced this? Thanks!
Old 05-17-2017, 01:58 PM
Default Re: MBox Pro v3 with External Mic Pre's
2 things to try;
#1-change the +4 switch to the other position(you never know).
#2-insert a balanced in-line pad(Shure and Sescom are 2 companies that offer these).
Old 05-19-2017, 07:17 AM
The levels are naturally hotter on -10. Just wondering why the hot levels into the MBox compared to other A-D's? Anyone?
Old 07-13-2017, 12:12 PM
Bump!
Old 07-13-2017, 02:35 PM
Ben Jenssen's Avatar
I never used that interface, but I would assume that it has a control panel software of some kind that would be able to set the input levels. Just guessing.
Old 07-14-2017, 10:46 AM
Thanks Ben. All settings are correct on the interface/control panel. Just wondering if anyone else has experienced hotter levels into the MBox Pro compared to other interfaces. Contemplating a move to an Apollo soon anyway.
Old 07-14-2017, 03:19 PM
Can't you just roll back the control panel inputs, say -10db, and have a less sensitive input?
Old 07-14-2017, 04:06 PM
The hardware gains are turned down all the way. Will check the software settings again but I'm only asking because everything seems to be setup as recommended.
External Pre's with Mbox Pro 3 AnnexProjekt macOS 2 03-02-2013 01:12 AM
So how do I get my external Mic pre into Mbox 2 lexaudio macOS 1 02-21-2013 06:28 PM
using external pre amp on mbox 2 advision205 Tips & Tricks 2 01-06-2011 09:11 PM
Using an Mbox 2 Pro with external Mic Pre? gsguitarest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2010 11:50 AM
External Pre to Mbox ? Shan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-12-2005 04:40 PM
