Old 05-11-2012, 06:55 AM
RichrdC RichrdC is offline
Default Midi velocity question
For some reason when recording drums using Xpand2, I notice the drum stikes can sound louder or softer. I figured it was me hitting the Oxygen49 keyboard harder or softer, but after concentrating on my hits for quite some time, I think something else is going on.. My question here is, is it possible to change the velocity of drum hits on an entire track at one time so all the velocity hits are at the same level?
I might as well ask here if there are any settings on Xpand2 that might be causing the different sounding hits, even though nothing is being changed while playing? Thanks for any insight, Richrdc
Old 05-12-2012, 01:50 AM
Vovique Vovique is offline
Default Re: Midi velocity question
Pro Tools upper menu > Event > MIDI Real Time properties > activate Velocity tab > now by setting Minimum and Maximum velocity value you can make all incoming hits the same hardness. Minimum=127 makes it hardest. You can obviously set a range in between as well (say, min 115 max 127).
Old 05-15-2012, 09:48 AM
Vovique, Thanks so much for the directions...
Old 05-30-2016, 12:32 PM
Jcalla Jcalla is offline
This worked for me, thank you!
MacBook Pro (16-inch, 2019), 2.3 GHz 8-Core i9, 16 GB RAM, macOS 10.15.7.
M1 Mac mini, 16 GB RAM, macOS 11.6.4.
Mac Pro (Late 2013), 3.5 GHz 6-Core Intel Xeon E5, 16 GB RAM, macOS 12.2.1.
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
Apollo Twin DUO MKII
UAD-2 Satellite QUAD Thunderbolt
MIDI Velocity Question Steve@ZooWest MIDI 5 08-21-2010 02:04 PM
MIDI velocity question Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-25-2009 08:00 PM
midi question (velocity-PT/Reason) hornedrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-19-2006 03:28 AM
editing midi velocity question don c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-05-2006 11:08 PM
PT midi velocity question .. jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-12-2005 08:48 AM
