Old 11-12-2011, 07:04 AM
xterraguy xterraguy is offline
Default Problem with 003 rack
I use Pro Tools 8.0.5 on windows 7 (64 bit). When Pro Tools loads, i get a message that reads "unable to locate Digidesign hardware". I uninstalled the 003 rack drivers and downloaded the latest 003 rack drivers. After installing the latest drivers, i launched Pro Tools again. I still get the same message "unable to locate Digidesign hardware". Has anyone else had this same problem?
Old 11-12-2011, 08:25 AM
Default Re: Problem with 003 rack
Can you test the 003 on somebody else's system to rule out a fried firewire port(which can happen if you hot-patch the firewire). A new firewire cable is worth a try as well(they do fail for no reason). Maybe post a Sandra report so the experts here can see if you have a compatible firewire controller in the computer(not all are compatible). Check this thread:
Help us Help You - READ THIS Before Posting!
ddwhitney ddwhitney is offline
I get this message more than I like.
Usually what I have to do it reboot my PC, turn the 003 off and then back on and then Pro Tools will find it. Sometimes I have to click "OK" on the "unable to locate Digidesign hardware" 4 or 5 times before it finally see's the hardware. If that doesn't work, I did have a bad firewire cable once about 3 years ago that was a new cable.
Good Luck!
Digidesign 003R+PT 2020.12.0, Gigabyte GA-Z97X, CPU INTEL i7-4790 4.0Ghz, CORSAIR DOMINATOR 16GB; ATI Radeon™ HD 5450 PCIe Multiple WD Caviar Black 2Tb Spinner Drives; 1 PPA 80GB 1394 Firewire Oxford 911 PYRO PCI64R2 3 Port Firewire Card (PCIe) Antec 300 case. PSU 600W,
Windows 10 Home.
Old 11-12-2011, 08:25 PM
YYR123's Avatar
YYR123 YYR123 is offline
+1
+2
Daniel
Old 11-13-2011, 01:02 AM
zedhed's Avatar
zedhed zedhed is offline
Are you using the firewire bus on your motherboard, or do you have a firewire card installed?
In any case try; Whilst connected to internet, Control Panel>Device Manager>IEEE1394 Bus Host Controllers>expand and double click on 1st controller>Driver Tab>Update driver (select automatically choose)>OK
If you have the right chipset on the firewire bus you should get a Texas Instruments 1394 OHCI Compliant Host Controller driver installed automatically.
Repeat for any other controllers showing.
Also, make sure your 003R drivers have installed properly by checking in Control Panel>Device Manager>Sound Video and Game Controllers. With 003 switched on you should see a DFU entry. If it doesn't show, reinstall drivers with 003 switched off then reboot with it switched on.
Also under normal use, I've found it best practice to turn 003 on then boot computer and when finshed shutdown computer then turn 003 off. I used to get the occasional problem with corrupted drivers but since doing this I don't have any problems now.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 07-09-2017, 01:36 AM
fakhrodin fakhrodin is offline
Friends please help
When I plug in a microphone static or dynamic input signal is very low, even with the gain max.. Sound card volume too must be kept
I noticed a broken transistor or diode
When completely destroyed beyond recognition.
Thanks for help
FOH rack vga problem brinnbacka VENUE Live Sound Systems 8 12-25-2011 12:15 PM
Major comp. problem - considering reverting to 002 rack instead 003 rack, good move? Tbassist4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2009 04:20 PM
002 rack problem djflava 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-15-2008 01:53 PM
002 Rack Problem ripreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-04-2007 04:44 PM
PROBLEM WITH NEW MAC PRO & 002 RACK Addison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-24-2006 09:05 PM
