HD Omni and ADAT Lightpipe
I just tried using a lightpipe to connect a Focusrite Octopre to an HD Omni, but for some reason only two extra inputs showed up. What gives? Does the lightpipe really only add another two inputs or was I doing something wrong? I was running at 48kHz.
Re: HD Omni and ADAT Lightpipe
The Omni does a *total* of 8 inputs. Widely discussed on DUC in the past and explained in the user guide.
Sounds like you have optical set to S/PDIF instead of ADAT.
True about 8 combined inputs, though. |
Yes, I understand it does a total of 8. I'm saying the ADAT lightpipe only added two inputs, so there was a total of 6.
As mentioned, it sounds like it's set to Spidf, rather than Adat.
You should be able to set that up in the
Hardware Setup section in Pro Tools. Just surf thru those tabs and you should find what you need to change the inputs to Adat optical
Not trying to hijack the thread here, but I have a relevant issue with my Omni. I record all my sessions at 88.2, hence the need for both ADAT inputs on the back of my Omni and the SMUX protocol. Currently I am running out of an Audient ASP880 via two ADAT cables so that all 8 channels can be transmitted at the 88.2 sample rate. Both the Audient and the Omni say they can do this by using both outputs on the ASP880 and both ADAT inputs on the Omni. Clock is locked, I/O in ProTools is set up so that all 8 inputs on the Omni are ADAT, but I can only get the first 4 to receive signal through the Omni. For some reason, when I try to use the last 4 channels from the ASP880, there is no sound or signal present in ProTools. The I/O is set up correctly in PT in both setup and on the PT mixer, but no sound is passing through. I have signal in the last 4 channels of the ASP880, and signal out of the ASP880 (light pipe is red and kicking), but it is not getting in the second ADAT input of my Omni. What am I missing? It has to be something easy I am missing. Any help in identifying my mistake would be greatly appreciated!
Originally Posted by The Egg: Be a Pro and stop being a Tool! Mac Pro Rack (7,1) 16-core 3.2gHz Intel Xeon W OSX Catalina (10.15.4) 8TB Mac OEM SSD System Drive (3) 1Tb 7200rpm audio hard drives 192Gb RAM Radeon Pro Vega II Video Card 2 Avid HDX Cards 2 Avid 8X8X8 HD I/Os; 2 Avid 16X16 HD I/Os PT Ultimate 2020.3 |
Exactly.
...but you did
First I would, swap the Adat into the Omni. Not out of the 880 but only the connections at the back of the Omni. This will point to which system has the issue. If it's the Omni you should see the inputs 4-8 (880) making movements on the meters in the session (still showing inputs 1-4 in the session and on the Omni)
96 I/O, ADAT lightpipe, and SR >48k | Iain Graham | Pro Tools TDM Systems (Mac) | 2 | 07-20-2006 11:39 AM |
002 lightpipe out ADAT | Banister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-12-2006 11:58 AM |
ADAT Lightpipe | Adagio12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-31-2004 08:15 PM |
ADAT Lightpipe with 001 | atrest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-22-2004 12:39 PM |
ADAT bridge: same as ADAT lightpipe cable? | Jim S | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-16-2001 07:37 AM |
