Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-10-2012, 11:13 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default
As learning exercises try these and see where it gets you:
Mixing by just doing balances & pan.
Restricting pans to L/C/R and 50% soft pans when needed.
Using a buss comp instead of using indiv channel comps.
Exagerating structural song/compositional dynamic differences using automation snapshots.
You'll notice I never mentioned the word EQ.
Cheers!
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 02-10-2012, 04:10 PM
bashville bashville is offline
Default Re: Dangerous D box?
Originally Posted by bonzerboy View Post
I guess what i am saying is ok lets say I create a mix and it is good i like it it. summing it thru the d box will not make a night and day fifference as an a & B comparrision?
"Night and day" no.
Some improvement--probably. But maybe not the first thing you need.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 02-10-2012, 08:44 PM
bonzerboy bonzerboy is offline
Thanks for the feedback
Wow am I groovy or what
Old 04-01-2012, 02:07 AM
i have now changed my moniters so that has helped in what i am hearing
Old 08-17-2017, 11:44 AM
a2c a2c is offline
Is anyone using this? with the digi 003. I do not know anyone who has one and most reviews are more like a cheerleader or just raving about the features. Can this device really help make mixes better.?
How do you guys connect mp3 player, iPod, laptop 3.5mm stereo into the CD (digital) of D-Box input?
  #16
Old 08-17-2017, 09:18 PM
Sardi Sardi is offline
Can you not use the analog input on the DBox? That's what I use for ext. input from phone etc.
  #17
Old 08-18-2017, 09:17 AM
a2c a2c is offline
Yes, I already used the analog from Mac's audio output.
  #18
Old 08-18-2017, 02:11 PM
Emcha_audio's Avatar
Next step would be to work on your mixing space so that you can improve the acoustic. THIS ALONE will give you much better results than anything else, beside practicing at getting your skills better.
Manny.
Wave-T.com
  #19
Old 08-18-2017, 03:09 PM
Things to consider:
1-Recording/session format? If you are recording at 16 bit and/or 44.1K, try 24 bit/48K. The hit on the system is quite modest but sound will be better(all other things being equal)
2-Quality of the input. Cheap mics into the 003 preamps will sound ok, at best. To get better(let's assume the talent is good because it starts there), you need a better mic(we don't know what you have) and a better preamp(Neve and API clones are a step in the right direction).
2(continued)-room acoustics. A bad sounding room will affect anything that is recorded with a microphone.
3-Mixing environment. The best speakers in a poorly treated control room will cause you to hear inaccurately, and you will likely make poor choices in EQ settings. speaker position in the room can also make for major differences in what you hear. If you can't hear an accurate sound, you probably won't get a good mix, especially in the low end. Think 200Hz down to 40Hz(low E string on a bass guitar is 41Hz). Bass guitar/synth and bass drum are probably the toughest things to get right in a mix(good advice already on checking with really good headphones).
Back to the D Box; if all the above isn't right, the D Box won't fix it Once all the above IS right, the D Box might earn its cost
Dangerous 2-bus! Peterjk Tips & Tricks 140 08-16-2005 08:12 AM
Dangerous 2Bus - Dangerous? NY909 Pro Tools TDM Systems (Mac) 2 03-28-2004 10:57 AM
Dangerous 2 Bus clarpark Pro Tools TDM Systems (Mac) 5 07-14-2002 10:08 AM
Dangerous 2 bus Still No SSL Yet Tips & Tricks 1 06-08-2002 02:36 PM
Anybody use the Dangerous 2-Bus? jackruston Pro Tools TDM Systems (Mac) 14 06-04-2002 12:18 AM
