Old 11-17-2017, 06:43 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Default Symphony I/O with HD Native - lots of relay clicking
Hoping to shed some light on a couple questions.
Been using a Symphony I/O 24 I/O with one of the Accel rigs and it's been very stable. Switching between PT and Stand-alone modes creates relay clicking, as I'm sure you guys have heard before.
Just started using the same Symphony I/O with an HD Native setup on the trashcan Mac Pro, but I have some concerns.
After some in-house testing we ran it for a couple live sessions and we were getting relay clicks quite often. About 6 during the loading of PT. Clicks sometimes when adding plugins, clicks sometimes when adding tracks and things like that. Also two freezes during the session.
We had a PCIe HD Native card in a Thunderbolt Magma chassis. Figuring it was something to do with that we got a HD Native Thunderbolt instead. Same relay clicks quite regularly, but haven't had any freezes yet (knocking on wood).
Are you guys using Symphony I/O (not the black one with the tiny display) hearing quite a few relay clicks while using yours? This exact same Symphony I/O has been flawless with Accel, so I don't think there's an issue with it, but maybe this is just part of the territory with HDN and Symph I/O.
Any experience would be appreciated.
Old 11-19-2017, 04:12 AM
syMPh syMPh is offline
Default Re: Symphony I/O with HD Native - lots of relay clicking
unfortunately symphony is not very useful with hd native.. when your cpu load gets close to 100% or even when it spikes on smaller sessions it can trigger a relay click, dropout of audio etc. whereas any other interface would just keep going.. the MK1's only really work well with HDX or TDM... I found it works great natively with a pcie64 card (no clicking natively under same conditions) but you lose the hd card benefits obviously.. you would find with a hdx card it is very useable.
System Details
Old 11-19-2017, 06:33 AM
Drew Mazurek's Avatar
Mine's connected to an HD Native PCI card in a machine room.
I'll do some tests tomorrow, but I think I only get relays switching when changing sample rate.
Will check.
www.drewmazurek.com
Old 11-19-2017, 01:13 PM
Maro Records's Avatar
Maro Records Maro Records is offline
Hi, the same here.
I've been working almost 3 years with Symphony I/O MkI on USB mode, and 2 months ago I've added HD Native PCIe - ...yes...hearing these relay clicks annoys me too.
But I found something about it from apogee:
http://www.apogeedigital.com/pdf/Sym...structions.pdf
I suppose it's normal behaviour ...
Old 11-19-2017, 04:26 PM
Thanks for the responses!
Are you guys ever experiencing system or PT hangs?
Old 11-19-2017, 09:22 PM
YYR123's Avatar
YYR123 YYR123 is online now
So do the clicks change behavior?
Does it impede recording ?
Does it cause PT to hang?
I have found a good deal on one of these mk1 units and i want to use it as a 2nd io for my HD|N
Daniel
Why hasn't track folders been implemented yet? - Thomas Jefferson
Old 11-20-2017, 01:35 PM
No system or PT hangs. It's stable , but ... these clicks ...
I found that it's much better when Maestro is closed when using PT.
Maro,
http://www.marorecords.com
Old 11-20-2017, 02:04 PM
YYR123's Avatar
I assume they can update the firmware to change this right?
How is Apogee’s service and support ?
Daniel
Old 11-20-2017, 02:51 PM
Just did some tests.
I only get relay clicking when launching PT, quitting PT, or opening sessions with different sample rate.
No clicking when inserting plugs or making tracks.
www.drewmazurek.com
Old 11-20-2017, 04:40 PM
Used to be awesome. Now they don't have phone support, but it's still okay.
Apogee Symphony 64 w/ Pro Tools Native HD clancychris Pro Tools HDX & HD Native Systems (Mac) 6 10-26-2017 01:12 PM
HD Native With Apoggee Symphony jaminjamesp Pro Tools Software (Mac) 8 02-09-2016 01:58 PM
Pro Tools HD Native & Apogee Symphony IO errors Chris Coulter Pro Tools 12 3 09-07-2015 07:32 AM
hd native + apogee symphony? ericlees Pro Tools HDX & HD Native Systems (Mac) 12 01-23-2013 04:38 PM
HD Native/omni vs Apogee symphony Matchless Gift Pro Tools HDX & HD Native Systems (Mac) 10 04-16-2011 07:41 AM
