Old 10-30-2017, 07:11 AM
Mano Mano is offline
Default PT hangs after initiating offline commit or bounce
Since a week ProTools hangs when i try to initiate an offline commit or bounce.
( application not responding)
This is very frustrating because offline committing tracks speeds up my workflow when working with softsynths and samplers.
Also with mastering tracks: normal aax based plugins like comps, reverbs, eq's...
Anyone out there who knows how to work around or kill this bug.
( the bug started spontaniously...i did not update or installed anything last few weeks...)
Old 10-31-2017, 08:23 AM
Default Re: PT hangs after initiating offline commit or bounce
HEAT on/off? PT Version?
rich@richbreen.com
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 10-31-2017, 10:18 AM
Trash prefs, suspect plugins, and if not that a corrupt session. Standard troubleshooting focusing on those things should get you sorted there, start under “help us help you” up top of every DUC page. Not much point in posting more here until you have been through that. And if you need more help, then much more info is needed, system details, versions, exactly what troubleshooting you have tried, etc.
HDX? Remember when you commit or offline bounce on HDX it is running those plugins Native not DSP. That switch may be the thing causing the trip up here. So a interesting test is does real-time bounce work O.K.? If so it’s more likely plugins than corrupt session. You can also try a session running against built in output.
Old 11-01-2017, 08:36 AM
Hanging on Commit or BTD with HEAT enabled in 12.8 and 12.8.1 is a known issue. Supposedly fixed in 12.8.2 (though I haven't confirmed).
rich@richbreen.com
Old 11-06-2017, 02:02 AM
Dind't know about the HEAT bug...Thank you so much Darryl en Rich !
Disabled HEAT Works fine now
Old 11-06-2017, 02:10 AM
JFreak's Avatar
JFreak JFreak is online now
Great :)
Janne
Old 11-06-2017, 01:19 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Fixed in HD 12.8.2
(Help us Help You)<<<click here
Testing:
Pro Tools U-18.7 MacOS 10.14 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire 7950Mac 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(HUI- MIDI over IP)
Surround-music-design-creation.
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
pops and clicks in offline commit tracks fmo Pro Tools 12 3 03-07-2016 03:23 PM
Commit Sound Quality - or is it offline bounce? JKR Pro Tools 12 4 11-09-2015 03:08 PM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
003 LE hangs says 003 offline jonw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-08-2008 10:33 AM
