Old 10-22-2017, 12:03 PM
rstreber rstreber is offline
Default Re: clock changes to 192k when I quit PT?
Interesting. Did anyone find a solution, even of changing the "default" sample rate to 96k? I just want to avoid switching over to a 3X rate.
Old 10-22-2017, 01:12 PM
Drew Mazurek's Avatar
Did you try changing sample rate in the audio MIDI set up app?
www.drewmazurek.com
Old 10-22-2017, 02:35 PM
priorytools priorytools is offline
I was having this happen a while back.
I went into audio midi sep up & in there it was set to 192. I changed it to 48 & the issue was resolved.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.11.6 / Pro Tools HD 12.6.1 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V3.6 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.5 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.6.1 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
Old 10-22-2017, 07:35 PM
Thanks for pointing me in the right direction, I think that did it! I had actually checked Audio MIDI setup before, but only when Pro Tools was running which meant that the HDX option didn't appear. But I went back with PT shut down, changed it over, and that seems to do it. Thanks!
Old 10-24-2017, 04:39 AM
syMPh syMPh is offline
Default Re: clock changes to 192k when I quit PT? [solved]
I'm a bit late to the party but it does this with my symphony's as well... even though you have discovered that changing core audio fixes it I find that often it forgets that it's been "fixed" and defaults back to 192... I think this is OS/ Core Audio which is the problem . is yours staying put on 48 now you've changed it or are you finding you have to keep updating it every once in a. while?
System Details
  #16
Old 10-27-2017, 01:20 AM
martthie_08 martthie_08 is offline
Symphony here, huge PITA problem, as I have 100feet Digilink cables and cannot reset to 44.1 from within ProTools.
In fact, I have to do a full hardware reset on the main (clock master) Symphony IO whenever this happens.
Sometimes I can get it back from within Audio/Midi Setup but not always.
Pro Tools 10HD won´t sync to word clock [SOLVED] Simon Johansson Pro Tools HDX & HD Native Systems (Mac) 2 01-31-2016 12:49 AM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
003 R+: Quit PT, open CoreAudio Manager = no sound!! (><) SOLVED UltraNEO* 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-04-2009 11:05 AM
automation quit working on one chnl.. (solved) tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-22-2007 08:34 AM
Clock problem solved, but still somewhat unsure ryanstack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-30-2005 01:29 AM
