Old 06-20-2002, 01:26 PM
monkey monkey is offline
Default timed stutter effect...LIke tremilo but not
I want to have a guitar quiclky cut in and out in time with pt. Ideas?
Old 06-20-2002, 02:00 PM
jackruston jackruston is offline
Default Re: timed stutter effect...LIke tremilo but not
1. try chopping the guitar up manually.
2. you can use a separate source to trigger a gate to release when you want it to.
Jack
Old 06-20-2002, 02:06 PM
Good ideas. Thanks. The gate idea is great. How about a plug in that does this? Perhaps pitchblender? Sounds simple enough for a plug in.
Old 06-20-2002, 02:27 PM
Submersible Submersible is offline
The Digirack gate will do it, but you need a suitable audio track to key off of, and that's not always easy. Maybe a drum track that is itself gated, or best of all, a drum machine track programmed the way you want it.
If your session is aligned to the grid, it's just as easy to set the grid to 16th or 32nd notes and delete every other note.
Old 06-20-2002, 03:27 PM
I've never tried it but couldn't you just use sections of generated noise or tones to trigger the gate?
J
Old 06-21-2002, 06:50 PM
Dopamine Dopamine is offline
Hey guys, check this simple and incredible effect. It's my favorite PT trick!
Go into the volume automation, select a grid value of 32nd notes. Then use the triangle tool to draw in automation. The effect will be the audio "stuttering" in and out right on beat!
Have fun and tell me what you think!!
http://www.phuturetrax.com
Old 06-28-2002, 06:27 AM
MAProTulz MAProTulz is offline
Amplitude modulation will give you what you want. I'm not sure if there's a plug that will do it, but I know that I can make it happen in SoundForge. I like the automation tricks though...very slick
Dan Roth
Otitis Media
Dan Roth
Otitis Media
otitis-media.net
Old 06-28-2002, 09:06 AM
haze haze is offline
mondomod/metaflanger by Waves (in the Gold, platinum, Effects bundles). There's a preset that makes the audio (i've done it on a vocal) sound like your singing through a fan. Pretty cool.
haze
www.johnhaze.com
Old 06-29-2002, 04:30 AM
Wyn Wyn is offline
If you are aligned to a grid. Generate a click at the interval you want the "stutter/tremelo to be, record it to a track, use it as a key source for the gate. If you are not aligned to a grid, use Beat Dectective to generate a tempo map, generate a click from that, use it as a key source for the gate.
Wyn Davis - Total Access Recording Studios
Redondo Beach, California
Old 06-30-2002, 06:27 AM
MMazurek MMazurek is offline
Pitchblender has a preset for it.
Stutter effect popping problem Danny Winn Tips & Tricks 6 09-08-2013 11:40 AM
Stutter Effect Adam Christopher Pro Tools 10 2 07-22-2013 12:10 PM
creating stutter effect in PT bonfi64 Pro Tools TDM Systems (Mac) 15 11-16-2010 09:10 PM
Stutter effect t0rn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-09-2009 08:36 PM
Stutter effect blackfader 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-16-2008 06:13 AM
