new hardware recognition in old session
I am still running PT 7.1 with and HD3 system (Mac). The system has always been configured with two 192 I/O's. I recently added a third 192. Any sessions created before the addition of the third 192 do not allow it to be configured for use. They see it but it can't be configured. The inputs and outputs can not be routed and made available. I have several on going projects for which I would like to use the third 192. I have tried creating a new session and importing the data from the old session. The third 192 is usable until the old session data is imported. I think I can import audio files only and get it to work. But this leaves me with a lot of work and time to recreate everything I have already done on the previous sessions. Is it possible to get older sessions to recognize the added 192? Any suggestions/solutions or references to previous posts that cover this issue would be appreciated. Thank you.
Re: new hardware recognition in old session
I made the original post. I have worked the problem more. I found that I can configure the third 192 I/0 in sessions created prior to when it was added but the inputs do not show up as usable in the session. Curiously, the third I/O outputs and inserts are available. Only the inputs are a problem.
FWx recognition by osx | xcx | VENUE Live Sound Systems | 2 | 12-03-2013 06:31 AM |
Firmware Update Causing No Recognition of Hardware | EarBud | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-05-2007 04:10 PM |
hardware recognition problem | Baltazar | Pro Tools TDM Systems (Mac) | 1 | 10-23-2000 05:55 AM |
SLEEP MODE and hardware recognition?? | stink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-09-2000 12:03 AM |
Name Recognition | TedRackley | Pro Tools TDM Systems (Mac) | 4 | 01-27-2000 06:26 PM |
