OD DeEdger by Tokyo Dawn Labs
DeEdger introduces a new way of reducing the hardness of audio signals without negatively altering the original signal qualities. The plugin operates in a threshold free manner, thus can comfortably handle any input signal level, type, and dynamic range. Where other plugins might under or over process, DeEdger only applies processing if any hardness is detected. Once detected, the hardness will be smoothed with remarkable elegance. After its initial setup, DeEdger can be left in a “set and forget” configuration without further attention. Intricate time and frequency dependent mechanisms allow DeEdger to provide a very transparent process throughout. The initial concept, developed by a professional mastering engineer, focused on the demands of modern audio mastering and has also turned out to be equally useful for mixing. Key Features
More details here: DeEdger | Tokyo Dawn Records |
Re: OD DeEdger by Tokyo Dawn Labs
A maintenance up date is now available;
1.1.0 btw - If you think a hundred bucks is a lot of money for an intelligent, set-and-forget de-harsher/de-boxer/de-esser/dynamic EQ, like all TDR plug-ins the demo version is unrestricted in time and functionality. The only restriction is it won't re-call settings. (Remember track sheets..?) Awesome! T
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 Last edited by Muddy-T; 07-19-2017 at 07:32 PM. Reason: punctuation |
New TDR Limiter 6 GE by Tokyo Dawn Labs | FabienTDR | AAX Plug-ins | 2 | 07-19-2017 07:08 PM |
Dawn of the Planet of the Apes: Will Files on Pro Tools and Dolby Atmos | Tom Graham | Post - Surround - Video | 4 | 01-01-2015 05:09 PM |
How to go Mac at the dawn of Leopard? | Yosemite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-01-2007 09:07 AM |
OT- Anyone here in Tokyo? | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-14-2002 09:48 AM |
PT LE and Tokyo 2.5 | t0kdag0n | MIDI | 3 | 03-17-2001 12:05 AM |
