Old 03-27-2019, 10:41 AM
Neale Neale is offline
Default Setting up an "add time at the end" macro
Hello, all.
I'd like to try to set up a macro to use either via my Artist Control with a custom softkey or even just a Mac OS keystroke.
I have an ongoing editing job where, after trimming the dialogue, I have to add 0.5s at the end of each region for the final output. I edit the empty spot out between the dialogue sections, tab to the end of the region, enter 0.500s in the counter, shift+option+tab to go to the start of the region while keeping the 0.500s at the end selected, shift+option+3 to consolidate.
The thing that is stumping me is how to specify the 0.500s in the macro. In other words, I figure I'd go to the start of a region, then program the macro as:
-tab (to go to end of region)
-specify the 0.500s somehow
-shift+option+tab to select to start of region including the 0.500s at the end
-shift+option+3 to to consolidate
Anyone have ideas?
Thanks!
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! italianguitar Eleven Rack 15 03-20-2012 01:57 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"Bouncing" . . . . Can I CHANGE The "Default Setting"?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 02:59 PM
setting levels "naturally" vs. what "the books" say Felix Tips & Tricks 8 12-19-2001 05:23 PM
