over lapping audio files without creating a pause
hi, im trying to figure out how to keep my wave files that have tails on the same track but without causing a pause at the end.
for example: I record a basic 4 bar pad pattern, usually pads have tails that exceed the 4 bars. right now what i do is record a pad and create a 2nd track thats entitled "PADS 2" and just copy and paste it back and forth every 4th bar. If i put the 4 bar pattern on 1 track you would hear a break or pause at the start of every 4th bar because the tail of the pad doesnt drag out. is there a way to paste the patern on the same track over the tail end and not remove the audio? thanks |
Re: over lapping audio files without creating a pause
Using 2 tracks like you have been would be the way to go. You could try using one track with a crossfade between the regions, but it most likely won't give you the result you're looking for.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I've had this problem in the past too, and one way I've solved it by using one track is to record 12 bars (3 x the 4 bar phrase) and loop the middle 4. This way you retain a 4 bar section featuring the softer attack, a 4 bar section with the tail intact and a 4 bar section that has a natural crossover. You'll likely still need cross fades between your loop points.
HELP!!! -1407 error while creating audio files!!! | PRS2300 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-24-2011 12:52 PM |
Error (-1405 while creating audio files) | PRS2300 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-29-2009 07:52 AM |
Creating Real Audio Files | Jeffrey Talbot | Pro Tools TDM Systems (Mac) | 1 | 06-06-2005 11:55 AM |
(-5000) while creating audio files | gravakords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-28-2005 09:46 PM |
